Home > Technical (L322) > Differentials and transfer box oil change
MC-RR
Monaco 2012 Range Rover HSE 4.4 V8 Ipanema Sand
Hello to all.
Finally got all the materials to change oil in the front and rear differentials as well as the transfer box.
Land Rover dealership in the south France are totally ridiculous with appointments and pricing.
Anyway, was waiting for the 500cl syringe and 14mm Allen key needed for the front diff to get started.
Since "The Beast" just reached 145000Km (90K miles?) was definitely time to get fresh oil in her.
Was surprised how straight forward and rewarding (fun) the job was. Hardest part was raising the beast enough to slide under to reach the diffs and transfer box.
Started with the Transfer box: obviously always undo the filler plug first before removing the drain plug. All you need here is a 8mm allen and a bit of force to crack them open.
The oil was definitely in need of changing. Since i had 2 litres of oil and only needed 1.5l i flushed the box with a couple squirts of fresh oil. On each diff and box drain I let the oil drip a good time until no drops appeared.
Replaced the copper washers on both plugs before filling with 1,5l of specified oil.
Next was the front differential, this requires the 14mm allen. Was aftraid it would be harder to reach the plugs but with an extension was a breeze. Very tight but not worrying. hardest part was removing under body protection. Again released the filler before removing the drain plug.
Oil was quite black and a very small amount of metal powder/paste coated the magnet on the drain plug. Nothing excessive.
Flushed again with a squirt of new oil then syringed about 750cl of oil after installing drain plug. Slight overflow on last centilitres.
Last did the rear diff. 8mm allen for filler plug and 3/8 socket for drain plug, again a bit tight but quite easy to reach. The oil was not as black as the other but was definitely in need of a change.
Squeezed 1.15cl of fresh oil and closed up the filler plug.
All in all took about 2 1/2 hours, mostly spent filing the 500cl syringe at proper levels and injecting the oil in the boxes. The syringe was quite slow and required multiple fills.
A fun afternoon job requiring only basic mechanical skills. Total cost less than €100, nearly a tenth of local LR dealer quote for the 3 changes.
Took the beast for a test drive and I did feel a nice difference, seemed quieter and smoother. Run through the whole range of gears high/low and felt wonderful.
All the best, RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Triumph TR6 1976 - Jeep CJ7 1976
Post #684223 29th Jan 2024 3:12pm
kevinp
The underside of your car looks very clean. The transfer box looks almost new. Thumbs Up
Post #684232 29th Jan 2024 5:28pm
MC-RR
I wash very thoroughly after my outings Rolling with laughter RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #684238 29th Jan 2024 6:32pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Nice job Thumbs Up ,got mine to do just waiting for the weather to sort itself out
Post #684282 30th Jan 2024 7:28am
drphilgarner
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
Good guide, thanks 2011 4.4 TDV8 Vogue
Post #685408 11th Feb 2024 10:57pm
MC-RR
Thumbs Up RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #685455 12th Feb 2024 4:01pm
MT
United Kingdom 2006 Range Rover HSE 4.4 V8 Alveston Red
Good write up, thanks. Have to agree above car looks clean and rust free!!
Post #686855 1st Mar 2024 1:34am
Epson Green
Excellent write up. What size are the copper washers on the transfer box plugs? Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #687011 2nd Mar 2024 11:44pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
That's one of the main advantages of living in a hot climate and not having salt on the roads during the winter! 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687049 3rd Mar 2024 1:03pm
MC-RR
Indeed RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #687184 4th Mar 2024 5:29pm
MC-RR
Not really sure. I have a kit with several sizes since I also play with Vespa's and motorcycles. Confused RR HSE TDV8 4.4 2012
Jaguar S type 3.6l
Jaguar XJ8
Jaguar X type 3l
Post #687186 4th Mar 2024 5:31pm
PDC
I saw on YouTube If you gently heat up your old copper washers to red hot and let cool off they regain their softness and can be reused. Thumbs Up 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687438 7th Mar 2024 11:28am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
As long as they're not too flattened, annealing a copper washer will allow it to be reused. I've done it for decades and never had any issues. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #687446 7th Mar 2024 12:31pm
yorkshire-dave
I am following this guide and so far so good for the transfer box and front diff. The rear diff is another story.
It was a bit of a pain figuring out which were the correct part numbers for the replacement drain/fill plugs. The transfer and front diff parts were correct.
Some posts indicated that the rear diff fill and drain were the same superceded part. I have got two 3/8th square plugs TYB500110 - does anybody know if this is correct? The current fill plug is a H8 as per this original post.
Additionally, there seems to be two drain plugs, one H8 and another the 3/8th square. I have seen other posts saying both drain and fill are H8 which is confusing. I assume I want to leave the H8 alone and drain with the square plug?
I have a locking ediff in case that makes a difference.
Here are some photos - hopefully somebody can ease my mind and confirm these are the correct plugs to remove and whether I have got the wrong replacement fill plug:
Drain plug(s?):
Fill plug:
 2010 Autobiography 5.0 SC V8 Petrol
Post #715662 6th Apr 2025 3:32pm
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
I'm about to do this project as well. My Autobiography is overdue. I just received the special Land Rover fluid for the eLSD (50$ per litre!).
Great to see another member in the Principality. I have a 2010 L320 SC at my flat in Fontvieille.
 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #715745 8th Apr 2025 2:18am
