Home > General > What Did You Do In Your Full Fat Today
Page 368 of 385 <123 ... 367368369 ... 383384385>
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Ordered yet another non-essential..
Today I ordered a Venturecam mount. Do I need one? No. But it looks intriguing and well, you never know….
 Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2010 Mercedes R230 SL63 , Tenorite Grey
Post #684754 4th Feb 2024 11:26pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Passed MOT for yet another year! Had her for nearly 11 years now😃 Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #684950 7th Feb 2024 12:56pm
RobErica
Netherlands
Fitted the Fat Lady with her new shoes, on D3 wheels.
Time to order 20 new wheelnuts me thinks.
First have to look for a set of roofrails for the tent.
Post #684951 7th Feb 2024 1:14pm
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Got the old girls MOTd with a pleasantly short list of advisories
Post #685188 9th Feb 2024 3:08pm
Big Vee
United Kingdom 2019 Range Rover Autobiography SDV8 Corris Grey
Tried out my homemade wheel fitting guides, worked as intended
Post #685936 19th Feb 2024 12:27am
PeteT80
Passed MOT with no advisories Very Happy
Post #685950 19th Feb 2024 1:50pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
First MOT pass with me.
4 advisories - O/S/R & N/S/R lower suspension bush worn and O/S/R & N/S/R subframe bush worn. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #685966 19th Feb 2024 3:19pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
My wife took ours to her parents over the weekend.
Just after she set off it threw a fault on the dash.
I told her to turn it off and back on and the fault was gone.
I told her "it's a Land Rover remember!" Laughing
Post #685982 19th Feb 2024 6:20pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
New coolant bottle (resolving the "low coolant" warning).
New airbox screws, as one was missing, one had a badly stripped head, and all were rusty with mangled heads.
New lighter socket plug, as it was missing, and that annoyed me.
Post #686003 19th Feb 2024 9:25pm
GraemeS
Australia
Yesterday I finished the job started the day before to replace the leaking radiator and all the hoses and plastic in the V including the hoses to the EGR cooler. I also fitted the sender unit for an oil pressure gauge. Lots of the plastic fittings/pipes broke when trying to disassemble, including the known fragile bleed fitting on top of the water outlet. However I retained my brass fittings and standard hose for the bleed line from the donut to the top radiator hose to avoid breaking the connection to the top hose again in a couple of years' time.
Post #686200 22nd Feb 2024 11:16am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Fixed the annoyingly loose rear bumper protector trim that'd got the end lifting. Removed it, the end moulded plastic tab was missing, probably broke off years ago if it was ever there, cut one of the middle tabs in half and used a combination of hidden drill holes and Gorilla 2 pack resin glue to secure it in place. Left overnight on the radiator.
Fitted it this morning, job done, not loose at all, doesn't rattle, no lifting or flapping, let's see how long it holds.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #686483 26th Feb 2024 9:57am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Replaced the driver seat base foam with a new one Shocked
Post #686484 26th Feb 2024 10:06am
AndyRoo
Fixed the Seat Heater with the new peltier from Aliexpress, £40 after getting the parts back from the guy who was supposed to fix it but that all fell through.
All seems to be working fine now, repaired the bellows rather than replaced, car did not catch fire yet due to Chinese sourced parts, time will tell on the durability but at the moment, nice heated seats again, Result.
Post #686666 28th Feb 2024 12:28pm
Gremlin500
……….. V6 Vogue - “Less is More” - less to go wrong!
Post #686668 28th Feb 2024 12:56pm
supershuttle
Went to get KFC Geoff
Post #686937 2nd Mar 2024 10:09am
