Home > Wheels & Tyres > Which Tyres?
Page 7 of 8 <12345678>
Jordie Barrett's sock
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I have a set of wheels (from my L320 Sport) which have an elderly set of Yokohama 285/35/22. I know the PCD is OK, but not sure of the offset. When the weather warms up a bit I might have to swap a wheel to see how it looks.
The rolling diameter is almost identical so I don't think they'll look 'small wheel syndrome' but even though they're only 10mm wider, might get the 'Tonka Toy' look.
Post #682540 12th Jan 2024 6:27pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I need one new rear tyre but my supplier says I should buy two to have them identically worn.
Is that necessary? Thanks
Post #688783 23rd Mar 2024 12:29pm
I've heard this before. But I'm sceptical.
Different diameters on one axle can ruin the diff, but consider my Sport had 20s from the factory and a 17" spare, draw your own conclusions.
A new tyre will have 8mm of tread vs part worn of say 4mm. A difference of 4mm in diameter will make hardly any difference to the circumference.
Post #688788 23rd Mar 2024 1:05pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I recently changed from pirelli scorpion to Michelin Pilot Sport 4s, a complete game changer, better grip and quieter as well, thoroughly recommend. Thumbs Up Thumbs Up
Post #688793 23rd Mar 2024 1:27pm
Stelen
Generally speaking, its said that 4mm is the tread depth tolerance measurement to keep all the cogs and gears of the transmission in the right place.
Post #688795 23rd Mar 2024 1:51pm
I concur ^^^^
Post #688798 23rd Mar 2024 2:15pm
Richie N
Thanks gents, sounds like I’ll be fine with one new one..👍
Post #688804 23rd Mar 2024 2:50pm
Bear In mind, if rhe remaining tyre on the axle is quite worn, it might be an idea to get it replaced as well.
Post #688805 23rd Mar 2024 2:52pm
What state is your spare wheel in ? (assuming full size spare)
I usually throw that into the mix & put the closest pair onto the car - sometimes it means a new spare, other times not.
Post #688811 23rd Mar 2024 3:16pm
Richie N
Yes, that’s a good point 👍 I need to check before making a decision.
Post #688817 23rd Mar 2024 5:24pm
Sandyt
I used the Michelins and bout the Pirellis a few weeks ago and I have given them 3k to get used to but changing back to Michelins absolutely superb ib Wet as well Thumbs Up I run Goodyear Ultrgrip winters and they are another superb tyre
Post #688913 24th Mar 2024 8:50pm
JayGee
An all season tyre is not going to do as well in the wet as a summer tyre unless it's quite cold. If you can run 2 sets winter and summer there is no compromise. 2012 TDV8 Vogue (L322)
Post #688965 25th Mar 2024 5:43pm
Sandyt
At the moment Costco £792 for 4 Michelin Pilot Sport 4 255 55 R20 for 4 Thumbs Up
Post #688966 25th Mar 2024 6:23pm
Martin2
The problem with UK winters is a proper winter tyre is still a compromise unless you live in the North/Scotland as it can be below freezing one day and in double figures a few days later. In my experience, winter tyres aren't great at 10c+, although that is on more performance orientated cars than a FF. I think a set of decent summer and all season tyres is the best way to go. That's what I've put on my wife's Golf R and I had on my 750i, but I have a winter set on the Porsche as it's the only option. The summers are back on now though and what a difference.....in a good way!
I ran Scorpion Zero All Seasons on my L405 and they were fine for the type of car it is. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #688967 25th Mar 2024 6:28pm
It's the dry where summers excel at most temperatures
In the wet, an all season tyre should be better except when it's very warm
Source -
Post #688968 25th Mar 2024 6:35pm
