Home > Maintenance & Mods (L322) > Fittings brake lines
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
I discovered a tiny puddle under the drivers side (LHD) door this morning, and soon after I got the low brake fluid warning light.. I was waiting for it, so not a huge surprise.
I'm gonna have to bite the bullet and make the brake lines for the big rangie.
I'm going with copper tubing, but what diameter pipe should I use, and which thread connections should I get?
I remember there was a great thread/guide somewhere here on fullfatrr but I can't seem to find it.
Post #689892 4th Apr 2024 12:45pm
wiki? ... - .- -.
Post #689895 4th Apr 2024 12:57pm
Faukstad
Silly me.. Razz
Thanks for pointing me in the right direction Stan.!
Post #689896 4th Apr 2024 12:59pm
Baltic Blue
Cunifer, an alloy of copper (Cu) nickel (Ni) and iron (fer) is the best choice, rather than pure copper.
Buy a roll, (plenty on eBay) and they will outlive the car.
Post #689899 4th Apr 2024 1:07pm
Faukstad
Does anyone know the dimensions of the "larger" fittings?
Post #689903 4th Apr 2024 1:37pm
Baltic Blue
http://www.fullfatrr.com/forum/topic25799.html
Post #689906 4th Apr 2024 2:01pm
Faukstad
Yes, I found the guide.
It didn't say what size the large fittings are though.
Post #689907 4th Apr 2024 2:03pm
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
Larger unions are M12 x 1. Smaller ones are M10 x 1.
I have recently replaced all the brake pipes. I needed 2 rolls of Cunifer 3/16 or 4.8mm as the front to rear pipes are quite long and if you make a mistake there is insufficient in one roll (guess how I know!).
I split the rear pipes in to 2 pieces with a joiner in just in front of the rear wheel arch where there is an access plate on the fuel tank guard so the joint can be inspected. L405 2018 5.0 S/C
Post #690189 7th Apr 2024 9:34pm
