![]() | Home > Maintenance & Mods (L405) > Swimming Lessons with My Range Rover |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Oh dear ! was it the sunroof drains ? 2021 P400 Silicon Silver AB
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 368 ![]() ![]() ![]() |
Oh no, I feel your pain. That’s one reason I don’t dare open the sunroof on mine. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1476 ![]() ![]() ![]() |
Richie N I would definitely check, pop the roof open and hold your breath. keeping it shut wont make any difference, other than hiding the issue.
I didn’t need to hear that 😫😉 |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 109 ![]() ![]() ![]() |
Just like you, I had a phobia of opening my sunroof, terrified of angering the gods of rubber seals and drains. But in the end… well, that's a story for a rainy day! |
I'll keep you all updated and might need some advice. I've been running a space heater in the back to dry out the headlining up front. Hoping to get it to my mechanic today to uncover the root cause. |
Fair enough, I will bite the bulllet and have a look. And I will follow your thread with interest. Good luck. |
Right, after a good look, my drain flanges aren’t rusted, just a bit of gunk in there. Turns out, the epic downpour we had just swamped the drains. Even my mechanic noticed other Range Rovers in their yard with the same fate. Surely expecting a car to handle heavy rain isn't too much—unless you’re dealing with JLR!
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 142 ![]() ![]() ![]() |
I don't believe that 'not opening' the sunroof will make any difference. I don't have one on my L405, but on my P38, the sunroof itself was expected to leak. This leaked water is captured by the sunroof drains and taken away.
That’s great news. And I will check out the drain cleaning tools. It’s a shame we can’t use air..
I heard through the grapevine that blasting your pipes with compressed air could wreak havoc, especially if they're a bit on the rusty side. But, you be the judge!
Yes, I read that the rubber lines are not secure enough and can come off the metal drain tube. Another great design 🙄
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8618 ![]() ![]() ![]() |
Salsbury & Richie N
Ah, the infamous ACE hydraulic pipes, designed with all the durability of a chocolate teapot! Sometimes, I daydream about whisking a JLR senior designer away to a secluded spot just to have a very spirited chat about their, let's say, 'unique' approach to durability. |
