Home > Maintenance & Mods (L405) > Swimming Lessons with My Range Rover
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Ah, the unparalleled delight of clambering into your trusty Range Rover post-deluge only to discover an unexpected indoor swimming pool, courtesy of what I can only imagine are Land Rover’s most mischievous engineers, playing their version of "Wet Surprise". Time now to dismantle the interior, wrestle with those accursed drain pipes, and repair the dam breaches.
And there I was, foolishly thinking I might escape the notorious aquatic hex that seems to be a rite of passage for every L405 owner. These engineers must possess a brilliant yet twisted genius—ensuring that owning one of these beasts isn't just about driving, but an ongoing battle against the elements, inside and out!
Post #692118 7th May 2024 11:37pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Oh dear ! was it the sunroof drains ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #692126 8th May 2024 8:44am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Oh no, I feel your pain. That’s one reason I don’t dare open the sunroof on mine.
Post #692139 8th May 2024 11:34am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Richie N I would definitely check, pop the roof open and hold your breath. keeping it shut wont make any difference, other than hiding the issue.
Salsbury, keep us posted on progress, and good luck
Post #692148 8th May 2024 2:12pm
Richie N
I didn’t need to hear that 😫😉
Post #692150 8th May 2024 2:39pm
Salsbury
Just like you, I had a phobia of opening my sunroof, terrified of angering the gods of rubber seals and drains. But in the end… well, that's a story for a rainy day!
Post #692161 8th May 2024 4:49pm
Salsbury
I'll keep you all updated and might need some advice. I've been running a space heater in the back to dry out the headlining up front. Hoping to get it to my mechanic today to uncover the root cause.
Post #692163 8th May 2024 4:52pm
Richie N
Fair enough, I will bite the bulllet and have a look. And I will follow your thread with interest. Good luck.
Post #692167 8th May 2024 5:23pm
Salsbury
Right, after a good look, my drain flanges aren’t rusted, just a bit of gunk in there. Turns out, the epic downpour we had just swamped the drains. Even my mechanic noticed other Range Rovers in their yard with the same fate. Surely expecting a car to handle heavy rain isn't too much—unless you’re dealing with JLR!
And I've discovered sunroof drainpipe cleaners are a thing. Who knew? I’m ordering one, and you might consider it too.
https://www.amazon.ca/s?k=car+drain+pipe+c...nb_sb_noss
Post #692330 11th May 2024 2:11am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I don't believe that 'not opening' the sunroof will make any difference. I don't have one on my L405, but on my P38, the sunroof itself was expected to leak. This leaked water is captured by the sunroof drains and taken away.
This means that the drains do have to work properly.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #692332 11th May 2024 7:36am
Richie N
That’s great news. And I will check out the drain cleaning tools. It’s a shame we can’t use air..
Post #692333 11th May 2024 8:10am
Salsbury
I heard through the grapevine that blasting your pipes with compressed air could wreak havoc, especially if they're a bit on the rusty side. But, you be the judge!
Meanwhile, a mate from the land of burgers and muscle cars swears by chucking Clorax—pretty sure it's just bleach—down his Discovery drains every so often.
And it other news, I've just been informed that my ACE lines are quite rusted $$$$$$$$$$$$$$$$
Post #692375 11th May 2024 5:45pm
Richie N
Yes, I read that the rubber lines are not secure enough and can come off the metal drain tube. Another great design 🙄
What’s the deal with ACE line? Expensive? I had an advisory on mine recently.
Post #692460 12th May 2024 3:37pm
Salsbury & Richie N
Info here including price...
https://www.fullfatrr.com/forum/post672742.html#672742
Be sitting down.... JLR warranty doesn't cover them as they fail by corrosion... Pete
-Click here for Thread-
Post #692468 12th May 2024 4:59pm
Salsbury
Ah, the infamous ACE hydraulic pipes, designed with all the durability of a chocolate teapot! Sometimes, I daydream about whisking a JLR senior designer away to a secluded spot just to have a very spirited chat about their, let's say, 'unique' approach to durability.
Post #692474 12th May 2024 6:16pm
