![]() | Home > Maintenance & Mods (L405) > Rear Seat Base Removal |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
Look under the front of the seat cushion, there are spring loaded clips that need to be 'rotated' while lifting the cushion, this releases the cushion.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
I find it easiest using my thumb |
I did that.. I also remember it hurting somewhat, must have sensitive thumbs.. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35803 ![]() ![]() |
craig has thumbs made of steel... |
batmanreturns Member Since: 16 Jan 2017 Location: Wiltshire Posts: 67 ![]() ![]() |
Ok, i've tried this and have located the little tabs but for the life of me can't work out if you pull them towards the front of the car, left or right or up?! They just seem locked hard in position. Has anyone got a video or some more advice on how to get these things out?! thanks |
@batmanreturns it is easiest if you remove the base of the seat by entering the left hand side of the vehicle with you landing up facing the right..
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I found an old tent peg bent at 90 degrees and used that, it did not hurt as much |
@tinman, indeed quite brilliant, wish I had thought of that when I first fumbled around trying to figure out this little puzzle whilst loosing skin....
Its easier to remove the seat base to clean the crap that falls between them and away from the connectors. 2017 SDV8 4.4 silicon silver AB
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Great post, no idea you could do this. |
zenman it's the only way to get to the various bolts should you need to remove the entire seat mechanism one fine day |
thanks, great video and i'll give it a go. |
