Home > Maintenance & Mods (L405) > Rear Seat Base Removal
batmanreturns
Hello, i can't find anything online about how i remove the above, does anyone have a step by step guide on removing the rear seat bases please?
Post #695400 2nd Jul 2024 12:40pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Look under the front of the seat cushion, there are spring loaded clips that need to be 'rotated' while lifting the cushion, this releases the cushion.
I struggled with this, it was not as easy as it looks on my fattie, very limited space and helps a lot if your wrists are double jointed...
Post #695401 2nd Jul 2024 12:50pm
I find it easiest using my thumb Thumbs Up
Post #695407 2nd Jul 2024 1:35pm
marcochezzi
I did that.. I also remember it hurting somewhat, must have sensitive thumbs.. Laughing Laughing
Post #695408 2nd Jul 2024 1:42pm
craig has thumbs made of steel... Thumbs Up ... - .- -.
Post #695413 2nd Jul 2024 2:37pm
batmanreturns
Ok, i've tried this and have located the little tabs but for the life of me can't work out if you pull them towards the front of the car, left or right or up?! They just seem locked hard in position. Has anyone got a video or some more advice on how to get these things out?! thanks
Post #695871 9th Jul 2024 10:18pm
marcochezzi
@batmanreturns it is easiest if you remove the base of the seat by entering the left hand side of the vehicle with you landing up facing the right..
Then, get your left index finger between the seat cushion and the clip , and pull towards you, ie towards the left of the car, and it will release.. It will also hurt your finger, unless of course you are a blacksmith, in which case your finger is probably too big to fit into that ridiculously small awkward space given to us by JLR engineers.. ..
I'll post a youtube video link shortly, just need to figure out how to do it..
Don't try from the right, its pathetically difficult trying to push the lever away from you..
edit: Here's the video link..:
https://youtube.com/shorts/UH1BdIlnsDo?feature=share
Post #695903 10th Jul 2024 1:47pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I found an old tent peg bent at 90 degrees and used that, it did not hurt as much Thumbs Up 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #695915 10th Jul 2024 4:14pm
marcochezzi
@tinman, indeed quite brilliant, wish I had thought of that when I first fumbled around trying to figure out this little puzzle whilst loosing skin....
Wonder if my son will notice a missing peg next time he goes on scout camp...?? Rolling with laughter
Post #695954 11th Jul 2024 7:02am
Tinman
Its easier to remove the seat base to clean the crap that falls between them and away from the connectors. 2017 SDV8 4.4 silicon silver AB
Post #695960 11th Jul 2024 8:42am
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
Great post, no idea you could do this.
Post #695993 11th Jul 2024 2:32pm
marcochezzi
zenman it's the only way to get to the various bolts should you need to remove the entire seat mechanism one fine day Thumbs Up
Post #695994 11th Jul 2024 3:15pm
batmanreturns
thanks, great video and i'll give it a go.
Post #696064 12th Jul 2024 12:01pm
