|  | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
| robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467      |
 well here is my photo picture story of the fitting of the paddles to my V8 4.4 54 plate 3005 model
|  25th Jun 2011 1:06pm |
 Well been busy this afternoon and here is the installation photo's for the receiver unit wired into the gearbox controll area and how I powered it up off an ignition feed.
|  25th Jun 2011 8:05pm |
 Well got the air bag off once the battery had been disconnected today and got stuck in!!!!
|  26th Jun 2011 7:55pm |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865      | thats the easy bit
 On the back of the TX as you turn it over: left button Left solder point = common Right solder point = NC Right button Top left solder point =common Bottom right solder point = NC "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back  " Last edited by pretlove on 26th Jun 2011 9:00pm. Edited 2 times in total | ||
|  26th Jun 2011 8:55pm |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865      | whats that massive electronic box for at the bottom of your steering wheel as on mine there was nothing there and thats where i fitted the sender "RANGEISM WILL NOT BE TOLERATED"
|  26th Jun 2011 8:56pm |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | well done rob!!! its looking really good! thanks for the great write up when i was working it out on mine i completely forgot to take pics of the install!!! doh!! i was too busy concentrating it completely slipped my mine! lol
|  26th Jun 2011 9:39pm |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865      | thanks matt i thought it may be that....as matt said great write up and lets not forget matt as its thanks to you and dave we have this mod at all  | ||
|  26th Jun 2011 10:30pm |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | glad me and dave could be of service!!......now, whats next we all need??????   | ||
|  26th Jun 2011 10:51pm |
|  26th Jun 2011 11:15pm |
 What would help everyone including me!, would be acouple of photo's of a wired up, swicthes removec transmitter!, any takers to supply this??? Current vehicles 4.2 SC FFRR RSE 2010- facelift Range Rover Evogue Dynamic Lux Gone Rejected RRS my14.5 nightmare Disco B4 XXV convert Freelander 06 SE 06 RFFRR 4.2 SC Vogue RSE Audi A8 4.2Tdi Quattro (hated with a vengence!!) 54 FFRR 2005 model V8 4.4 Cobra Variant 53 Mitsubishi Shogun V6 | ||
|  27th Jun 2011 7:17am |
| Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191      | I'll do it later today   | ||
|  27th Jun 2011 7:35am |
| Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191      | There's some pics in my gallery for you guys to looks at, note that only three wires are required.
|  27th Jun 2011 4:31pm |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865      | jonnos photo  | ||||
|  27th Jun 2011 4:41pm |
| allisong Member Since: 28 Jun 2011 Location: UK Posts: 9      | I have a 2007 Range Rover with heated steering wheel so do not have the additional circuits available through the "clock spring" as JLR call it, BUT studying the wiring diagrams I could see that the heated steering wheel wiring has a seperate ground and 12v supply wire (from the ignition) to the normal steering wheel switches. This is to allow it to be fused seperately I guess.
|  28th Jun 2011 1:17pm |
| Posting Rules
 if you go back to the start of the thread jonno explains where to put the wires i removed the switchs from the sender
