Home > Technical (L322) > Battery and gearbox
Philcaz
Battery and gearbox
Hi guys
I’ve got a question for you all can a weak battery cause my gearbox to play up at I’ve got a 2004 petrol v8 and I’ve noticed a slight judder sometimes but then I had to replace the battery and the judder seems to have gone
So my question is can a crap battery cause gearbox problems
Cheers Phil
Post #703124 26th Oct 2024 7:07pm
mjdronfield
I don’t believe so. The earlier ZF gearboxes are not known for their longevity in these heavy motors, though they are better than the GM box in the TD6.
Worth changing fluid?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #703127 26th Oct 2024 7:36pm
Philcaz
Thanks for the reply
Post #703128 26th Oct 2024 7:55pm
mjdronfield
I’m sure others will be along with a more useful answer….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #703130 26th Oct 2024 8:21pm
RRPhil
A weak battery/low voltage can certainly cause issues with the ECUs e.g. TRANS. FAILSAFE PROG messages, etc. but I doubt it would cause a transmission judder. The most common cause of this with the 5HP24 is wear of the torque converter lock-up clutch friction plate. A fluid change, or friction modifiers added to the fluid, can produce a temporary improvement but ultimately the converter will require replacing/remanufacturing.
The most common condition for the judder (which can feel a bit like driving over a cattle grid) is up at slight incline at around 30mph, if it is the LUC at fault.
Phil
Post #703146 26th Oct 2024 11:26pm
Philcaz
Thanks for that Phil
Post #703162 27th Oct 2024 10:35am
