![]() | Home > Technical (L405) > front knuckle cracking |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 36 ![]() ![]() |
Do we know if the 2019’s had updated parts? |
I’ve seen reports of a couple 2017 and 2018’s failing. |
StevieBoy Member Since: 12 Dec 2023 Location: Surrey Posts: 14 ![]() ![]() ![]() |
I’m sure they have, they clearly don’t care about the consumer.
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 149 ![]() ![]() ![]() |
I also wondered if vehicles that have had the replacement parts are failing for a 2nd time? I.e. since I've had mine done, do I still need to keep checking them.
Well - it certainly makes you question the ongoing credibility of the vehicle & organisation behind it. LR insist that the Recall notice I previously posted for your comment only covered 2014 & 2016 model yrs. I counsel your opinion - as I & many others read it as to cover 2014 to 2016 - Therefore including my 2015?
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87 ![]() ![]() |
Does anyone actually have the VIN range JLR is using for the recall that's not a recall? |
I couldn’t obtain it - the dealer inputs your Vin individually to ascertain.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Interesting that all the reports of failure seem to be at low speed. |
Mercedes W124s had a similar thing with front ball joints and the typical failure was for it to let go as you were pulling away. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1413 ![]() ![]() |
Pure luck I would guess! 2018 SE SDV8 4.4 Byron Blue |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 403 ![]() ![]() ![]() |
Vin range and knuckle batch numbers are listed on the TSB N759v3, I had a copy but cannot find it for the life in me. Maybe worth asking someone with Topix access to pull a copy off and upload it. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Extol Member Since: 13 Jan 2024 Location: London Posts: 13 ![]() ![]() ![]() |
This information available from the land rover N759 document, which is about the cracking knuckles.
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 111 ![]() ![]() ![]() |
I think all the force is when doing a tight turn, so at low speed. One fatality was on a motorway where it is thought the vehicle was making an avoiding manoeuvre. The car ended up completely destroyed by fire so the cause was speculation. 2017 (67) Vogue SE Corinthian Grey |
No - mine failed in a straight line. Philip’s comment re they seem to fail at low speed is I suggest incorrect, just that those that have failed at high speed have ended up in such a mess that the cause has not been identifiable as a knuckle joint failure whilst they’re picking the pieces out of the tarmac, motorway bridge, ditch or other vehicle. |
