![]() | Home > Technical (L405) > front knuckle cracking |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 462
If you look at the vin range, EA is model year 2014, FA is 2015 and GA is 2016, so how they can say 2015 is excluded is beyond me. Granted its certain vin ranges within each year, but is definitely over the 3 Model Years. My GA vin was some way lower than the start vin for 2016, but both knuckles were done under goodwill. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2628
I know of a fatality locally where one veered off the road, which, knowing where it happened, seemed a bit odd. |
| StevieBoy Member Since: 12 Dec 2023 Location: Surrey Posts: 14
You did well - Bravo Highlights of my CRC experience is attached... |
| Jef Benitez Member Since: 24 Jul 2018 Location: Warwickshire Posts: 4
Sent mine back in at Sytner LR in Cov (2015 vin SALGA3JEXGA27**** so seems to be in the middle of Period 2), both knuckles checked but not replaced, was assuming they would just do them as a matter of course but will keep an eye on them going forward.
The fault is caused by a mix - production corner cutting &/or over torqued when fitted.
| Extol Member Since: 13 Jan 2024 Location: London Posts: 20
I finally had the reply from Land Rover saying, the below.
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349
It's disgusting the way they are shrugging this off as it's clearly not limited to the VIN ranges that they have supposedly identified. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
The Model year identifier is digit 10 of your vin (D=2013, E=2014 etc.) and digit 11 will always be A for Solihull plant build, so to summarize the last eight digits will be model year, plant build and then 6 unique numbers for production build number (so FA000001 would be 2015 model year, first of the production line). Your vin starting SALGA3 breaks down to SAL (Landorver world identifier) G (Range Rover model) A (class standard) 3 (Long Wheel base). You need to look at the last eight digits of your vin and compare with the affected range. HTH L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
| Rio Member Since: 03 Jun 2024 Location: Albi Posts: 24
Me too / no idea what it is. |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1901
2 bits of angle iron and a bungee rope to get you home, if it ever breaks |
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1526
I don't believe that, only 12 claims in the US between 2015 & 2024!!!
| Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096
Taiwan isn’t part of China - yet! |
| Memoliito Member Since: 22 Feb 2024 Location: Corby Posts: 13
| All times are GMT |
