![]() | Home > My Range Rover > 5 RRs and I have to give up |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
A good 'result' - but bizarre 🤣 Paul,
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 752 ![]() ![]() |
Steering back to being 'ok' today (not perfect but not terrible just manageable)
Okay so this RR is doing something different to all the others.
That is weird!
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Tyre presures are lower when cold than when hot. |
I agree Pawl, I also agree Graeme.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3302 ![]() ![]() ![]() |
Cold makes the tyre compound stiffer which may cancel out or even over compensate for any pressure loss. Also I have found higher than stock pressures give me a better ride quality which maybe has to do with how tyre compliance interacts with velocity signals sent to the CVD ECU? Your drivability issues also sound like a leaky EGR valve and in cold weather the EGR valve opens less as I found recently when my average regen interval went from 80 to 560 miles and the EGR valve never opened more than 10-20 %.Worth checking the EGR error value and the difference between comanded and actual opening values . Mine seems to have a 4-5% error i.e the actual position is higher than the commanded. I'm now seriously toying with an EGR software delete. 2012 TDV8 Vogue (L322) |
Interesting information Jaygee, I'm sure the tyre and it's pressure do effect the way the CVD module will control your suspension.
Probably because I've made all these complaints about 2 later L322s before Jaygee |
Maybe worth doing the EGR software delete anyway through the GAP tool add-on as it's a wise move anyway to protect the turbo's 2012 TDV8 Vogue (L322) |
It's something I plan to do Jaygee but sadly I haven't an IID tool at the moment.
A thought that crossed my mind, when I did the power steering fluid replacement I used Smith and Allan cold climate fluid.
Okay so this just gets more and more confusing.
