![]() | Home > My Range Rover > 5 RRs and I have to give up |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
A good 'result' - but bizarre 🤣 Paul,
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Steering back to being 'ok' today (not perfect but not terrible just manageable)
Okay so this RR is doing something different to all the others.
That is weird!
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2784
Tyre presures are lower when cold than when hot. |
I agree Pawl, I also agree Graeme.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
Cold makes the tyre compound stiffer which may cancel out or even over compensate for any pressure loss. Also I have found higher than stock pressures give me a better ride quality which maybe has to do with how tyre compliance interacts with velocity signals sent to the CVD ECU? Your drivability issues also sound like a leaky EGR valve and in cold weather the EGR valve opens less as I found recently when my average regen interval went from 80 to 560 miles and the EGR valve never opened more than 10-20 %.Worth checking the EGR error value and the difference between comanded and actual opening values . Mine seems to have a 4-5% error i.e the actual position is higher than the commanded. I'm now seriously toying with an EGR software delete. 2012 TDV8 Vogue (L322) |
Interesting information Jaygee, I'm sure the tyre and it's pressure do effect the way the CVD module will control your suspension.
Probably because I've made all these complaints about 2 later L322s before Jaygee |
Maybe worth doing the EGR software delete anyway through the GAP tool add-on as it's a wise move anyway to protect the turbo's 2012 TDV8 Vogue (L322) |
It's something I plan to do Jaygee but sadly I haven't an IID tool at the moment.
A thought that crossed my mind, when I did the power steering fluid replacement I used Smith and Allan cold climate fluid.
Okay so this just gets more and more confusing.
| All times are GMT |
