![]() | Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel. |
Tommybuk Member Since: 17 Jan 2024 Location: Ellon Posts: 13 ![]() ![]() ![]() |
Hi. I didn't get any pics. I just remember finding the route across fairly obvious.
V9 SVO Member Since: 10 Dec 2023 Location: Cornwall Posts: 2 ![]() ![]() ![]() |
Many thanks |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 80 ![]() ![]() ![]() |
How confident are you in it being 16mm? 😂
2008 TDV8 Vogue SE 2002 TD6 Vogue 2002 Defender 90 TD5 2002 Range Rover P38 Autobiography 2002 Range Rover P38 Westminster Just a sucker for big bills!!! |
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 66 ![]() ![]() ![]() |
My 2018 4.4 with 62K mls has developed this leak, and I assume it’s from same spot as mentioned on this thread. Also found puddle underneath rear driver passenger seat. I’m going to call LR assistance out tomorrow and see if they can get the car into MD quicker and hopefully covered under warranty. Also hoping LR assistance can provide a replacement vehicle while mine is being repaired.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1522 ![]() ![]() |
It is fairly standard size coolant pipe. I replace mine a while back running from just behind the front wheel under the sill back to the rear left pipes in the wheel well area.
Update on my car, coolant leak from Aux pipes to rear heater console. Initially Warranty claim was rejected.
noone Member Since: 05 Apr 2025 Location: Florida Posts: 95 ![]() ![]() |
What purpose do coolant lines in the rear of the vehicle serve? 2023 L460 Range Rover SE P400
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 408 ![]() ![]() ![]() |
If the vehicle has 3 or 4 zone climate then you have an additional HVAC unit in the left hand rear quarter serving the rear passenger compartment. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 589 ![]() ![]() ![]() |
will have a check and see what mine are like |
ciprian Member Since: 23 May 2021 Location: Essex Posts: 6 ![]() ![]() ![]() |
I recently had mine done under warranty without any problems ,I think depends on who deals with your car and how much effort wants to put in it. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Who was your warranty provider? |
I got Land Rover extended warranty although is the las year as the car has over £100k miles now |
Ahhh, guessing it’s manufactures extended warranty from new and that’s why they don’t quibble! If it were JLR used it would be through a third party provider albeit hidden behind JLR blurb. Hence why after sales warrenty usually say no! And yours did not air… 👍 |
roel2018 Member Since: 01 Oct 2018 Location: Groningen Posts: 42 ![]() ![]() ![]() |
I made a bypass solution in a very simple way. A piece of EPDM hose 16mm thick and 1 meter long. Hose can go up to 120 degrees. I also had a coolant leak above the rear subframe so a very difficult spot. Thought of several possibilities but this is the simplest solution and costs 2 hours and 10 euros for the hose (1 meter). The aluminum pipes are loose about 1 liter of coolant when cutting the pipes. Be careful because at the first cut the coolant squirted out. So put on safety glasses and old clothes. I secured the rubber hose to the diesel tank mounts with tie raps so it's rock solid. The epdm rubber hose is pretty stiff so I had to heat it with a heatgun. With water pump pliers and some pulling and pushing I managed to pull this hose 4 cm over the aluminum pipe. Used 4 stainless steel clamps for 2 euro. The gray electricity box is only needed to make the workspace a little bigger. I used a multi tool to cut the aloy pipes. Watch out for the red flat cable and black thin plastic tube. Because otherwise you got a much bigger problem.
