Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel.
Page 3 of 3 <123
V9 SVO
I have just had the same problem and to keep me on the road I have simply with hacksawblade cut the hoses off closest to the rear and used copper pipe and compression elbows and stainless hose clips to bypass the rear. I like the idea of getting around to bypassing the rear pipes with hoses. Have you any photos of the route you took and if you had to protect the hoses from rubbing? Thanks
Post #706428 8th Dec 2024 10:41pm
Tommybuk
Scotland 2016 Range Rover Autobiography SDV8 Barolo Black
Hi. I didn't get any pics. I just remember finding the route across fairly obvious.
I started from the rear left wheel arch, at the rear heater pipes, and fed each pipe over the subframe then over the rear over the propshaft. There are other pipes and cables over the propshaft there, so you can cable tie the new pipes. I used 4 or 5 there to ensure it wouldn't foul the propshaft. Then it's an easy route to the 2 pipes underneath the right sill to join it all up.
The whole job took and hour or so. Must be nearly a year since I did it, and I've had no problems at all.
Good luck!! 👍
Post #706432 8th Dec 2024 11:02pm
V9 SVO
Many thanks
Post #706433 8th Dec 2024 11:09pm
Rich_Allen
How confident are you in it being 16mm? 😂
I’d quite like to order the pipe in before I put mine on the ramp…
Cheers Rich
Tommybuk wrote:
I had the same leak at the rear, from these crappy ally pipes on my 2016 4.4. Fixed for £50.
1. Identify the leaking pipe and follow it along where it comes in from the inner sill underneath the drivers side half way back. Cut the 2 ally pipes where they come in from the sill.
2. Remove rear wheel arch liner from the other side (passenger side). Identify the same 2 ally pipes, feed and return, going into the heater. Cut them off to about 4 inches.
3. Buy 4 metres of 16mm (measure to check size) coolant pipe to fit over the Cut ends.
4. Attach the new pipe to the Cut ends under the wheelarch and feed across the car, routing as required. There's different ways of routing without nipping the pipes.
5 fix the pipes with clips/ strong cable ties at sensible points to secure, under the car.
6. Cut and fix the new pipes where you've cut the ally pipes at the inner sill on the drivers side.
7. Bleed coolant as required.
Took about 2 hours or so, and most of the ally pipe is bypassed.
8. No problems/leaks since doing it 6 months ago. Thumbs Up
 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #714990 27th Mar 2025 5:17pm
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
My 2018 4.4 with 62K mls has developed this leak, and I assume it’s from same spot as mentioned on this thread. Also found puddle underneath rear driver passenger seat. I’m going to call LR assistance out tomorrow and see if they can get the car into MD quicker and hopefully covered under warranty. Also hoping LR assistance can provide a replacement vehicle while mine is being repaired.
What’s strange is I topped up 1litre of coolant after getting low coolant level warning 2 was ago. I’ve been checking at regular intervals, level was slightly dropping. Last checked on Saturday and level was middle of min-max, didn’t drive the car other than taking out of drive and back again and then when I started this morning I got Low Coolant Level warning, reservoir was bone dry to eye, It took full 1litre again.
So don’t understand why the coolant would be leaking slowly over 2wks while doing 200 motorway miles and then suddenly empty the reservoir?
Post #715316 31st Mar 2025 11:30pm
fisha
It is fairly standard size coolant pipe. I replace mine a while back running from just behind the front wheel under the sill back to the rear left pipes in the wheel well area.
Red dots mark which pipe is the same. V8 or else ...
Post #715326 1st Apr 2025 10:00am
Maher2023
Update on my car, coolant leak from Aux pipes to rear heater console. Initially Warranty claim was rejected.
But after further photos and details of location of leak etc by dealer to warranty team, they have now accepted to replace both pipes under warranty.
So if you do get initial NO by warranty, then ask dealer to send photos and detailed report to warranty and they might accept it.
Dealers have order replacements pipes and other fittings to carry out full repair under warranty.
Also they provided me a nice Mercedes S class hire car as loan car until my car gets repaired.
Post #716635 23rd Apr 2025 10:28am
noone
United States
What purpose do coolant lines in the rear of the vehicle serve? 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #716945 27th Apr 2025 9:58pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If the vehicle has 3 or 4 zone climate then you have an additional HVAC unit in the left hand rear quarter serving the rear passenger compartment. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #716947 27th Apr 2025 10:02pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
will have a check and see what mine are like Thumbs Up
Post #716959 28th Apr 2025 6:14am
ciprian
I recently had mine done under warranty without any problems ,I think depends on who deals with your car and how much effort wants to put in it.
Post #719891 16th Jun 2025 9:47pm
Who was your warranty provider?
Post #719897 16th Jun 2025 11:34pm
ciprian
I got Land Rover extended warranty although is the las year as the car has over £100k miles now
Post #719909 17th Jun 2025 7:04am
Ahhh, guessing it’s manufactures extended warranty from new and that’s why they don’t quibble! If it were JLR used it would be through a third party provider albeit hidden behind JLR blurb. Hence why after sales warrenty usually say no! And yours did not air… 👍
Post #719923 17th Jun 2025 12:23pm
Page 3 of 3 <123
