Home > Technical (L405) > front knuckle cracking
Page 47 of 54 <123 ... 464748 ... 525354>
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
IGP wrote:
Just found out my front nearside knuckle is cracked. Mines a 2013 SDV8 so not in the VIN range. £780 for a new one.
Ivan
Check out Range Rover world I think they are doing copies for sale for 500 quid. Just a thought/suggestion 2016 4.4 diesel
Post #707313 20th Dec 2024 7:41pm
sass
Finland 2016 Range Rover Vogue TDV6 Kaikoura Stone
@Gremlin500: What I meant was that are there any members around that knew they had completely intact/sound knuckles in the first place without any visible damage after becoming aware of this feature, but noticed them failing later on. It is a fault which you have to look out for, until the part fails completely. Based on the posts in this thread the failures seem to have happened ”under cover” over time.
I was after replies like @4RRS
I still have 9 months left of my 3rd party warranty so I am trying to anticipate what could/should fail next on my TDV6 with 125k miles. (Don’t even mention the crankshaft or the bearings Twisted Evil ).
Post #707315 20th Dec 2024 8:24pm
Gremlin500
OK thank you just meaning to clarify things, @4RRS you say “in minute detail” but was that with a proper crack testing kit, or just visual? It’s important to qualify these things when death can be the result. The dye penetrant and reactive indicator can reveal microscpic detail absolutely invisible to the human eye, in a night-and-day difference kind of way.
If you own an L405, you 100% need to own & use this kit regularly.
Just trying to keep everyone safe here on the forum, and no I don’t sell this stuff whatsoever! Evil or Very Mad V6 Vogue - “Less is More” - less to go wrong!
Post #707330 21st Dec 2024 1:36am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Sorry, i should have been clearer, I carried out the N759 recall as per the v2. JLR document and found no cracks at the time. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #707340 21st Dec 2024 9:23am
Gremlin500
Hmmmmm, makes you wonder exactly how JLR Dealers check the knuckles?
I’d lay odds on it’s just a visual check, -anyone know the answer? Whistle
Anyone notice if the joints were sparkly clean after a JLR “inspection”? Any sign of dye overspray?
I’d rather do it myself so I know it’s been done properly, for peace of mind.
It’s such a quick, easy DIY job, why trust anyone else with your life? V6 Vogue - “Less is More” - less to go wrong!
Post #707348 21st Dec 2024 11:12am
mpirie
I guess burying my head in the sand "safe" in the knowledge that my car was not in the affected VIN range and was too old ('63) is not enough anymore if '13's are now turning up with cracks! Big Cry
NDT kit ordered and on it's way! Rolling Eyes
Living out in the sticks means recovery would not be easy!
Mike
Post #707413 22nd Dec 2024 11:33am
Gremlin500
Sometimes recovery is impossible, no matter where you live! 💀⚰️🪦 V6 Vogue - “Less is More” - less to go wrong!
Post #707429 22nd Dec 2024 1:29pm
Gremlin500
On a lighter note, can I nag everyone about ALWAYS wearing eye protection when using a wire brush (including handheld) you don’t want even a tiny bit of wire embedded in your eyeball, or your skin for that matter, so wear some tough gloves when prepping for the test!
Have a Happy (and safe) Christmas! 🎄🎅🏼 V6 Vogue - “Less is More” - less to go wrong!
Post #707431 22nd Dec 2024 1:36pm
Matty1
Ivan
What's your manufacture date? you gonna try and push for LR to repair?
Post #707826 29th Dec 2024 6:21pm
Superty
United States 2016 Range Rover Autobiography 5.0 SC V8 Corris Grey
Has anyone had the “retaining bracket” fix applied as part of the recall? I’m keen to see how this is meant to prevent catastrophic failure.
Post #707844 30th Dec 2024 5:45am
LiKuid
Greece 2017 Range Rover Autobiography TDV6 Corris Grey
2017MY. I ve had a call with the dealer and he told me that “it’s an aluminium part and aluminium parts break. It’s normal…” I tried to keep calm…. If i try to push the dealer for a repair, it’s definitely gonna take time and i cant have the car stationary for weeks. I ‘ve already ordered the part and hopefully i will receive it today to replace the broken knuckle. However, i will let them know and will also do the test for the left one which has no visible signs.
Post #707858 30th Dec 2024 1:19pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Have we seen any replaced knuckles fail?
I have had mine done as part of the recall and am trying to decide if I need to monitor the new ones regularly...
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #707888 30th Dec 2024 9:06pm
I don’t think so as yet, but nothing wrong with keeping an eye on them.
It’s random how the originals fail some do, some dont. Mine are original and still in Minty fresh condition. There is nothing that can't be fixed with a hammer😜😜
Post #707889 30th Dec 2024 9:36pm
Gremlin500
@ChrisJC:
These knuckles are all now made by SAI in Taiwan since 2014, including the “affected” batches.
(The company is generally known as an alloy wheel manufacturer).
The opportunity for further defective castings persists.
It’s very cheap, quick, and easy to do a DIY periodic, (6-monthly) penetrative dye crack test for peace of mind, which is what I’m doing on our MY2017, even though it’s apparently not in the affected range.
There are reports of 2017 and possibly even 2018, vehicles being affected, depending on who you believe on the internet……….. V6 Vogue - “Less is More” - less to go wrong!
Post #707890 30th Dec 2024 9:38pm
Mikey
17MY, that was through our own workshop, and only picked up as the car was in for a service
Have seen pictures of, but not personally seen, 19/20MY still failing...
Post #707891 30th Dec 2024 9:55pm
