Home > General > What Did You Do In Your Full Fat Today
Page 378 of 385 <123 ... 377378379 ... 383384385>
StuManchu
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
Took it for it's MOT, passed with only 1 advisory, got a slight coolant leak, which I think may have been me spilling it when I topped it up yesterday ๐Ÿ˜‚ 2012 Westminster 4.4TDV8
Post #708798 10th Jan 2025 2:23pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Today I checked the auxiliary battery. Didnโ€™t have to remove it completely to see the manufacture date stamped on the negative terminal: Week 47 Year 12! ๐Ÿ˜ฎ
So itโ€™s original to the car. I canโ€™t believe that in a car with such a reputation for chewing through batteries that it hasnโ€™t been changed in 12 years!
New one on order.
Post #708860 11th Jan 2025 3:58pm
Caveman2000
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
I replaced my near side parking brake actuator!
Post #708866 11th Jan 2025 5:15pm
DesertGSD
United Arab Emirates 2019 Range Rover Vogue SE 5.0 SC V8 Loire Blue
Plan on using the FFRR more this year so got her some new tints and a bath, will be sending her in for a proper multistage detail before summer starts
As a bonus ran we into a nearly identical FFRR on our coffee run this morning
 โ€˜18 Vogue SE Supercharged ๐Ÿ‡ฆ๐Ÿ‡ช
โ€˜16 Sport SVR (gone) ๐Ÿ‡ฆ๐Ÿ‡ช
โ€˜11 Sport Supercharged ๐Ÿ‡จ๐Ÿ‡ฆ
โ€˜04 Discovery 2 SE7 ๐Ÿ‡จ๐Ÿ‡ฆ
Post #708908 12th Jan 2025 8:06am
garyRR
What did I do this weekend?
I fitted the facelift steering wheel buttons to my L405. If there was anything that let it down, it was how cheap the buttons sound when you press them.
The touch buttons are a step up in quality.
 2015 Range Rover Autobiography 4.4 SDV8
Post #709148 14th Jan 2025 10:03pm
DesertGSD
New engine mounts and fresh oil change. Had some jerking issues which I assumed was the transfer case but turned out my engine mounts were shot, all fixed and smoothness is restored.
Seems like they updated a few modules, I have no idea how but the sound system is insanely better than it was, bass is restored and it just sounds so much more clear in all modes where as before I could only get it to sound decently acceptable using the DTS option. I cannot put in words how much of a difference whatever they've done has made.
Instrument cluster got an update and is much smoother, scrolling through the menus and settings and the response is instant. Also is much less cluttered, no more little green triangle that used to be on all the time for the collision avoidance and lights are now just the green side lights and the auto in white which turns to blue when the adaptive driving beam is functioning where as before there used to be 3 little individual green indicators for each individual function. Don't know if it's just my mind playing tricks on me but I honestly feel the entire display is about 25% sharper, crisper and smoother than it used to be.
Post #709493 17th Jan 2025 7:55pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
I have installed a 1500W inverter so that I can have a coffee on my trips to Andalusia. The Nespresso machine draws 1250W, so there is enough power available.
Installed in the place where the factory jack was, socket above the 12V connection in the trunk and power is drawn from the secondary battery. Thumbs Up
Post #709625 19th Jan 2025 9:41am
hmallett
After an unsuccessful attempt yesterday to diagnose why my rear wash doesn't work (probably pumping screen wash into the cabin somewhere), and an unsuccessful attempt to swap the FBH with a replacement, today I have successfully changed the rear diff oil. Nice to actually achieve something!
Post #709692 19th Jan 2025 9:45pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Replaced both external mirror glasses back to tints as one heater had failed.
Both warm now, but they don't get toastie like my Nissan, not sure why the temp is so limited but it's been the same on all my LRs.
Still, a lot better than they were and look much nicer with the blue tint again.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #709763 20th Jan 2025 8:17pm
Merchy
Passed the MOT Very Happy and spent the rest of the day cleaning the car, tomorrow will be spent deep cleaning and treating all the leather.
Post #709784 21st Jan 2025 7:28am
AndyRoo
Stripped & serviced the suspension air compressor, Hitachi, replaced the piston rings & seals. Old one was not too worn, but thought I'd do as a precausionary measure as I had some spare time.
Takes a lot less time to get up to pressure so old one was definately on it's way out.
Post #710223 26th Jan 2025 1:52pm
Merchy
After recently passing the MOT, driving home yesterday lost all the air and had to crawl home through town with the car on the bump stops - not a nice experience, eventually found the leak on the front offside air bag. So ordered two new complete struts / bags as the car is 07 reg, been squirting penetrating oil EVERYWHERE, in preparation of removing the old struts on Monday, bad news with the weather though, looks like it will be a cold, wet and windy job Banging Head Big Cry
Post #710247 26th Jan 2025 6:31pm
mgrover
I replaced the wiper blades and god damn does it feel nice to have a clean screen Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #710327 27th Jan 2025 1:33pm
AndyRoo
Got around to fitting the replacement suspension relay from PowerfulUK as a preventive measure.
Also fitted the Bevinsee 80w LED dip bulbs that arrived today, will see how they work out tonight.
Also found these really cheezy mirror brows on Ali Express, so fitted them see if they work as my mirrors always dirty and rain covered. They look a bit naff, but hey, function over form right.
A.
Post #710596 30th Jan 2025 4:37pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Not very exciting, but ordered some Gtechniq L1 leather protector. Gave the seats a shampoo this morning as I like them protected. Found some L1 in the garage, but it was finished Big Cry so got Mr Bezos to deliver some on Saturday Thumbs Up
Post #710597 30th Jan 2025 4:51pm
