![]() | Home > Technical (L405) > Possible Turbo issues |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Have you looked at the MAP sensor yet to see if it needs cleaning Ash?
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
I haven't and will do today, but all through this journey so far, the sensor was always clean.
So - second day of the oil filter replacement - no loss of oil and no smell of anything burning - still looking good.
Hi Greame
Hmm…
sorry folks - me again.
Ash, I presume you have looked at the plenum chamber hoses to make sure they arn't split anywhere?
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
My gut feeling: The CSOV is changing over to the 2nd turbo ... but not changing back as well as it should. This would explain why you can drive it hard, but it fails when going back to normal driving. V8 or else ... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2732 ![]() ![]() |
DTCs?
Thanks Fisha,
OK - makes sense what you're saying, so CSOV likely working just fine. Based on that, and the original plausibility errors, my next initial thoughts / comments:
Hi Gang,
That's very interesting Dtech. My car never goes into restricted performance but I get an occasional chirping noise usually going from 3rd to 4th. I was checking the gearbox oil and noticed the left hand downpipe was 'cool', then there was a funny muted 'woof' sound and the exhaust pipe immediately got hot, but five minutes later was cool again. It kept doing this. Very strange. Just wondering if I might have a dirty valve like yours. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 76 ![]() ![]() ![]() |
The left hand down pipe can only become hot if the turbine shut off valve opens, but this would normally only happen when the engine rpm and load reaches the required level to activate it.
