![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 189 ![]() ![]() ![]() |
Like Abacus, I have a remote switch to isolate the OBD port and I leave the Vgate plugged in but switched off when not in use.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 505 ![]() ![]() ![]() |
Hello
eBay Item No. 204534747929. Fuse switch
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 109 ![]() ![]() ![]() |
I use an odb2 extension with switch. Just plug one end into the port and the obd2 reader into the other en. Here’s the one I bought, unfortunately currently unavailable on Amazon, but you get the idea
tomiRR Member Since: 06 Jan 2025 Location: Europe Posts: 16 ![]() ![]() |
Dear RegenMasters!
Hi Tom and welcome to the Society of Sootwatchers.
Dear Spridget,
darren3005 Member Since: 01 Nov 2023 Location: Somerset Posts: 66 ![]() ![]() ![]() |
Hi All
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1764 ![]() ![]() ![]() |
Hi Darren, yes sounds about right, very similar to mine actually, (it never drops below 7% for me).
Thanks Gremlin
Hi Darren, not the iid tool, but the “Kot Kit” (dongle + phone app) mentioned in the above thread, it’s well worth reading the lot! |
Dear Friends,
Hi Tomi, I think Stan will probs move you to a new thread topic with your question, but good luck. V6 Vogue - “Less is More” - less to go wrong! |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1380 ![]() ![]() |
How have you come to that conclusion? DPF's can be cleaned just G it using your location to find Garages near you. A suitable OBD2 tool can force a Regeneration and also indicate if there are any sensor failures which could also be the culprit. DPF can be cut out, and physically cleaned and installed for around £300 in UK, probably cheaper in Europe. Do a search on this forum there are lots of threads to study! 2018 SE SDV8 4.4 Byron Blue |
