|  | Home > My Range Rover > New to me 5.0 s/c L322 ab |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | First impressions, it's a 5.0 s/c so that's taken care of. Iv not been out of a fullfat as still been using my older one think I was 1 of the 1st on here to fit the flappy paddle mod. It's a nice place to be with It's black on black interior which seems almost unblemished.
|  29th Jan 2025 9:12pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Sounds like your starting off similar to me!
|  29th Jan 2025 10:18pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Thanks David, the chains have apparently been done. Iv had a good read of your posts and will look closely at that link about your gearbox work.   | ||
|  29th Jan 2025 10:46pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Investigated no access height fault today and was the common problem the cone shaped exhaust filter blocked so drilled a 1mm hole threw the centre.
|  30th Jan 2025 4:24pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Fitted the new lower tailgate straps I can now sit on the back of tailgate on last shoot day of the season as intended   | ||||
|  31st Jan 2025 4:45pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Fitted and tested my H7 main beam with led bulbs pleased so far as I upgraded all my bulbs in my D3 and sport. Os done for comparison with ns
|  31st Jan 2025 10:00pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Got it dirty and discovered iv got an intermittent wiper motor wipers got stuck twice today quick check on here and iv orderd a new motor after checking the linkage is all good 👍
|  1st Feb 2025 9:02pm |
| Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 434      | Very nice 👍😃 | ||
|  2nd Feb 2025 11:12am |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | So the new eBay wiper motor arrived yesterday and it's dry here today do set about swopping it out. Just the motor as others have said its fiddly but doable.
|  5th Feb 2025 2:30pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Time to install the optimate to the rear fuse box as iv had low power indicated twice so far dispite checking the battery and charge on the car I know there power hungry but !!!!!.
|  7th Feb 2025 4:33pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | After a 300 mile round trip yesturday it's time to start flushing the gearbox before the filter, bridge seal and tube seal replacment.
|  14th Feb 2025 12:15pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Have now replaced all of the gearbox solenoids reset adaptations but still have the shudder and rpm fluctuating on the motorway and still have the fault.gonna drive it like I stole it to see if it improves if not I think its torque converter time.
|  8th Mar 2025 11:37am |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | Having confirmed my tc needs replacing (big thanks to rrphil) in the mean time I'm getting round to doing a full service. Apart from the other previous odd jobs iv done this is now a must do. The car came with some service history from an independent from the previous but last owner and was serviced in 2022. It's not done a lot of miles since to be fair but on inspection when I pulled the air filters out they had a 2014 manufacture date stamp on them and the service history states they had been replaced twice once in 2020 then again in 2022   | ||
|  3rd Apr 2025 10:18pm |
 Do I or do I not have an E diff I do have a plug n socket on the rear diff topix says I do previous service history shows fluid change stating non ediff oil used  | ||||||
|  4th Apr 2025 8:05am |
| Posting Rules
 I think not.
 I think not.
