![]() | Home > My Range Rover > New to me 5.0 s/c L322 ab |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1025 ![]() ![]() |
First impressions, it's a 5.0 s/c so that's taken care of. Iv not been out of a fullfat as still been using my older one think I was 1 of the 1st on here to fit the flappy paddle mod. It's a nice place to be with It's black on black interior which seems almost unblemished.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
Sounds like your starting off similar to me!
Thanks David, the chains have apparently been done. Iv had a good read of your posts and will look closely at that link about your gearbox work. |
Investigated no access height fault today and was the common problem the cone shaped exhaust filter blocked so drilled a 1mm hole threw the centre.
Fitted the new lower tailgate straps I can now sit on the back of tailgate on last shoot day of the season as intended |
Fitted and tested my H7 main beam with led bulbs pleased so far as I upgraded all my bulbs in my D3 and sport. Os done for comparison with ns
Got it dirty and discovered iv got an intermittent wiper motor wipers got stuck twice today quick check on here and iv orderd a new motor after checking the linkage is all good 👍
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 371 ![]() ![]() ![]() |
Very nice 👍😃 |
So the new eBay wiper motor arrived yesterday and it's dry here today do set about swopping it out. Just the motor as others have said its fiddly but doable.
Time to install the optimate to the rear fuse box as iv had low power indicated twice so far dispite checking the battery and charge on the car I know there power hungry but !!!!!.
After a 300 mile round trip yesturday it's time to start flushing the gearbox before the filter, bridge seal and tube seal replacment.
Have now replaced all of the gearbox solenoids reset adaptations but still have the shudder and rpm fluctuating on the motorway and still have the fault.gonna drive it like I stole it to see if it improves if not I think its torque converter time.
Having confirmed my tc needs replacing (big thanks to rrphil) in the mean time I'm getting round to doing a full service. Apart from the other previous odd jobs iv done this is now a must do. The car came with some service history from an independent from the previous but last owner and was serviced in 2022. It's not done a lot of miles since to be fair but on inspection when I pulled the air filters out they had a 2014 manufacture date stamp on them and the service history states they had been replaced twice once in 2020 then again in 2022 |
Do I or do I not have an E diff I do have a plug n socket on the rear diff topix says I do previous service history shows fluid change stating non ediff oil used |
