Home > General > What Did You Do In Your Full Fat Today
Page 379 of 385 <123 ... 378379380 ... 383384385>
just a reminder to members that this is a 'one' post thread so please dont discuss or reply to posts as this spoils the thread..thanks.
Post #710603 30th Jan 2025 5:44pm
ThisIsMyUsername
England 2009 Range Rover Vogue TDV8 Santorini Black
Finally got my gap iid tool and was significantly disappointed with the lack of options i could change out the box but did turn on all the lazy options and locking and unlocking beeps.
cleared some fault codes that were historic and nonsense and got confused by the ones that remained 58 plate L322 3.6tdv8
England, Kent
Post #710946 3rd Feb 2025 5:07pm
Dolphinboy
drove back from Meribel (1600 miles round trip) having had a week of sun and snow (oh, and broken ribs!!)
Car was immense and never put a tyre wrong. even driving with broken ribs was a gas.
Post #710961 3rd Feb 2025 8:15pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Dropped mine off for a service at Robert Country Vehicles. They also investigated a minor coolant leak and tell me the thermostat housing needs replacing with associated hoses.
Otherwise its been given a clean bill of health so not a bad first year of FFRR ownership 👍😃
Post #710976 3rd Feb 2025 10:19pm
Merchy
Finally got round to changing my TDV8 3.6 front right strut ( complete strut with airbag )
Usually not too bad a job, out on the driveway, but it rained nearly all day, and when it came to the two bolts holding the strut to the knuckle, the top bolt came out OK, BUT.... the lower bolt was completely seized in the knuckle. It took ages using a a gas torch, then with the steering turned to hard right I was then able to swing a sledgehammer to free off the bolt it was a Censored Censored nightmare. Hence the job took me about 5-6 hours. Big Cry
One thing I noted was that the old strut I removed was a Delphi item, and as per the date on the label manufactured 2006, so as it lasted from 2007 ( Car build year ) to 2025 with about 142.000 miles on the clock, that is certainly a good advert for Delphi. This week I will check the age of the left hand unit, if that is old, then it will be replaced.......when the weather is dryer and warmer Whistle
So since about 2017 driving a TD6 and now also the TDV8 I have only had one breakdown in all that time and after the air bag failed, hence the job above, I still managed to limp home without needing recovery. Tempting fate I know, like an idiot, I had promised the grand daughter that I would tow a horse box tomorrow for her to compete hence working in the rain Big Cry Thud
Post #711934 15th Feb 2025 10:45pm
GregPrice80
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Attended a big Land Rover meet, followed by a drive out across Dartmoor. Well over 100 Land Rovers present. Mostly defenders, but there were a few Range Rovers. Managed to get some nice pictures…
 2010 Range Rover 4.4TDV8 Autobiography Black Edition
Gone -
2005 Discovery 3 2.7 TDV6 S
2002 Range Rover 3.0 TD6 HSE
Post #712048 17th Feb 2025 4:50pm
Gsxr1250dave
Fitted my new fullfat sticker supplied by Pete
The badge is straight it's the curved glass that make it look like it's not. After cleaning the glass and warming it up with my heat huns it's on
Post #712050 17th Feb 2025 5:13pm
PeteT80
Passed MOT, no advisories Very Happy
Post #712051 17th Feb 2025 5:26pm
range366
Scotland 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Handed her into an independent in Glasgow today…..
Driving home Friday night from work, heard a bit of a ‘pop’ with power loss then restricted performance, when accelerating onto the motorway.
Taking her down to the garage, she will initially pull away ok from a stand, then not much power until around 30, then pulls away ok….. so just waiting now see how many pennies!!
Post #712099 18th Feb 2025 1:12am
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Cleaned it thanks to some winter sun.
Note: Every Land Rover should come with the ever reliable Honda Civic mk8… 2009 pre-facelift 3.6 TDV8.
Post #712192 19th Feb 2025 12:28am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Replaced both front height sensors today, fixed my harshness problem completely, now back to wafting. In the end I used Aerosus units.
Unfortunately I had to destroy the old ones to get them apart, the Torx machine screws weld themselves to the brass threaded inserts in the sensor body and the plastic is pretty weak, you need to recover the bolts as new sensors don't come with them so you need to hack away the plastic to be able to clamp the brass fixing to get the Torx out.
Both brackets quite rusty so cleaned them up and rustproofed before refitting using some copper grease, hopefully if I have to take them off they'll be easy to remove.
Did the usual height calibration and CVD calibration afterward, all good now, hopefully for a long while.
Noticed the NSF sensor was not smooth, so that was probably the dodgy one, the other was stiff, but smooth.
Also got me one of them there stickers, looking mighty fine.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #712233 19th Feb 2025 3:55pm
JimFos
Took my 2003 for MOT; pass no advisories.
Post #712953 27th Feb 2025 5:59pm
Mutters_Mate
Found out why I couldn't get out of park even though the solenoid was working. Sticky cable between selector and ignition switch. Result. Mutters_Mate (Mark C)
2002 TD6 SE
Post #713188 2nd Mar 2025 6:50pm
Well yesterday:
Changed the oil cooler and o rings.
Today:
Drove to the East of England Land Rover Experience with Laddo for an afternoon go.
It’s been a green oval weekend Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #713191 2nd Mar 2025 7:06pm
AndyRoo
Replaced front discs, pads, 1 caliper & pad wear sensor and all the brake fluids.
Decided to go kool black rather than chavvy red.
A.
Post #713328 4th Mar 2025 10:13pm
