![]() | Home > Technical (L405) > front knuckle cracking |
| Glackowitz Member Since: 06 Sep 2020 Location: Oregon Posts: 18
Here is what I got back from JLR US after several emails into them about this.
| GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 21
My LH knuckle has now started to show the crack. I believe this may be the first case in Australia. Thanks to this forum and everyone that has posted I have been checking them regularly and have caught it at the early stage. I am now in discussion with JLR and have reported it to the local authorities (as it is still not a recall in Australia). My vehicle is a 2014 model from the “period 1” high risk period as identified in the US recall. Luckily I have been able to source replacement knuckles (latest part numbers) and will be having them installed by my local dealer (who has been very good to deal with on this matter).
This time with photo attached.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
GaryR, have you been keeping watch and if so, how long has it been since the crack wasn't visible? |
Graeme. I would say 5 months ago I saw the first marks that started the warning bells and then I took baseline photos. Then 6 weeks ago I thought it had gotten worse and then 3 weeks ago I concluded the crack was starting to open. |
Thanks. Didn't progress too quickly initially but gaining pace. |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1900
Although not in the “affected range”, I test mine with dye penetrant every 6 months for peace of mind.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
When I did the brakes the other week I gave them a good clean up and checked them over. Still all Ok. Agree the dye is best way but mine were visually fine and I gave them A proper clean and close look👍🏻 There is nothing that can't be fixed with a hammer😜😜
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Albeit, an L494. Exactly the same issue, noted during routine service. JLR not interested...
What year was that please, Mikey? V6 Vogue - “Less is More” - less to go wrong! |
16MY |
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Another knuckle x 2 look for Shopov's post
| dpm Member Since: 14 May 2018 Location: grimsby Posts: 48
Car taken in independent garage today for some work and they ring to say one side knuckle joint has a crack, i have looked at the VIN number and i think it falls in the recall batch, the garage says it not safe to drive, i have given them the go ahead to change the joint. Can anyone give me any advice as to who to contact in LRJ and ask for compensation on the cost of repair please. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Local dealer, I'd go to Duckworths in Market Rasen, (they are a site sponsor) ask to speak to the workshop manager and explain the situation, remember you need the other side doing as well if your vin is in the range...
| All times are GMT |
