![]() | Home > Technical (L322) > How To: Replace Fan Blower Motor on all models L322 02-12 |
woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 34 ![]() ![]() |
I've now done the job twice as I broke the fan blades when fitting the new blower last time. If you damage the blades you limit your blower speed and the ability to use full demist or full cooling in the summer. The noise gets worse as the fan 'hamster wheels' break up and you also ruin the blower motor cover which you then need to source used.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 254 ![]() ![]() ![]() |
Really useful - thanks Woody. Top tips and I'll definitely be making a note.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
If you follow my guide, there's no need to cut. Using the pry bar to gently lift the loom was sufficient to get the blower motor in and out. I'd also point out to follow my note around orientation when removing and installing the blower. 2015 Range Rover Autobiography 4.4 SDV8 |
Dmorela Member Since: 08 Apr 2025 Location: Texas Posts: 2 ![]() ![]() ![]() |
Got the new fan in no problem, great guidance!
There is a trick. There's a step in my guide on it. 2015 Range Rover Autobiography 4.4 SDV8 |
Your trick to remove worked great. I just dont have enough space to get my fingers on the side to guide the rod into place. Mainly because the drive air vent is in the way. I managed to bend it slightly but was hesitant to force it. I'll keep trying it |
Put it in 5mm-1cm above where it fits and at a angle whilst using a screwdriver to guide the rod into the groove, if you can't get your fingers in there. It shouldn't need any force. 2015 Range Rover Autobiography 4.4 SDV8 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
One thing to note is that the instructions in this thread don't cover all years. Early L322 and later L322 are significantly different. I think the later cars are easier to do.
What year model is yours, Woody? Mine's a 2003. I broke mine, too. I did a repair using fine bronze wire, dental floss, and superglue which seems to be holding up. i just avoid maximum fan speed.
This was the inside of the fan cover when I initially pulled it all apart. ![]() 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
The difference with the earlier cars is you need to cut out the panel behind the dash in order to remove the fan motor. As stated in my guide, there's is a particular angle in which to remove the fan motor, and you can use a pry bar to raise the wiring loom whilst removing the fan, if you need that bit extra clearance. 2015 Range Rover Autobiography 4.4 SDV8 |
Bristol RR Member Since: 20 May 2023 Location: Bath Posts: 21 ![]() ![]() ![]() |
Im at this stage too - have removed the two screws holding the flap panel in and can’t get the thing out. I can feel another screw which feels like it’s about a centimetre under the big stiff wiring loom. How did you get to that third screw? I can’t see any way to get at it let alone get a torx bit on it!! Was going really well until this point 🤦🏻♂️ Edit - mines a 2012 Westminster so looks like this third screw appeared towards the end of production. Thanks, James |
You’ve made better progress than me ! I got to the stage where I was hinting for that screw and couldn’t find it. Luckily for me, my blower motor is fine and I was doing it as part of the dash removal to change the radio unit.
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 111 ![]() ![]() |
Re the unwanted third screw.
