![]() | Home > Technical (L405) > New to me L405 4.4 errors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35764 ![]() ![]() |
the second problem is the little fan/sensor behind the trim to the left of the steering wheel... ... - .- -.
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 214 ![]() ![]() ![]() |
Thanks Stan, any idea how it comes off? Is it the same on a 2018 (as earlier models) just thinking mine has the different layout with two screens? 1972 Series 3 full of character
as far as i can see its the same...held in by clips and pulls off...theres a little fan thingy in there that gets clogged up with dust etc.
Perfect thanks Stan |
Little fan replaced, error gone!
Been following the trouble shoot guidance-
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
From the back of my mind:
Thanks Fisha it’s hard to know where to start as I don’t know what a healthy reading is.
Has some professional diagnostics carried out, EGR is capable of dropping the MAF reading however the actual and expected readings are inconsistent- suspected sticking EGR valve
Why not a spanner with another extension spanner on the end of it ? V8 or else ... |
The spanner / Ratchet has to come off at an angle to miss the crossover pipe and ends up hard against the bulkhead, now considering cutting a spanner down or maybe a stubby Ratchet?? 1972 Series 3 full of character
Got there eventually! Amazing what you can do with a cheap ratchet from the local hardware shop!
Anyone know if the oil and gunk under the oil/Egr cooler is ‘acceptable’ or do I have another issue?
Well all went back together and I was fault free for a while |
