Home > Technical (L405) > New to me L405 4.4 errors
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Anyone have any experience of these on a 2018 4.4?
P0401-00 Exhaust gas recirculation flow insufficient
I’ve read Ajmngn post on the l322 error I guess it’s the same for the L405?
B105A-71 Passenger compartment temperature sensor fan -
Actuator stuck any idea where is this located? 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #714190 16th Mar 2025 10:13pm
the second problem is the little fan/sensor behind the trim to the left of the steering wheel... ... - .- -.
Post #714192 16th Mar 2025 10:15pm
Andyyav
Thanks Stan, any idea how it comes off? Is it the same on a 2018 (as earlier models) just thinking mine has the different layout with two screens? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #714193 16th Mar 2025 10:19pm
as far as i can see its the same...held in by clips and pulls off...theres a little fan thingy in there that gets clogged up with dust etc.
if cleaning it doesnt work then replace.
this should help,
https://www.fullfatrr.com/forum/topic61610...fan+sensor ... - .- -.
Post #714195 16th Mar 2025 10:28pm
Andyyav
Perfect thanks Stan Thumbs Up 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #714199 16th Mar 2025 10:44pm
Andyyav
Little fan replaced, error gone!
Still investigating the EGR restricted flow error
Does anyone know where the ‘exhaust gas Recirculation electric actuator’ is on a 2018 I’ve looked in the area shown on Ajmngn post -
https://www.fullfatrr.com/forum/topic63391.html
But can find it, found a boost pressure control valve, is it anywhere near that??
Also found the electrical diagram for it in the 2017 WSM (guess it’s the same for the 2018?) which shows an approx distance from the ECM of 1870mm but I’m not even sure where the ECM is Embarassed
Any help or info greatly appreciated! 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #715299 31st Mar 2025 8:35pm
Andyyav
Been following the trouble shoot guidance-
- Intake air system, low pressure boost leak
- Exhaust gas recirculation actuator circuit short circuit to ground, high resistance, open circuit, disconnected
- Exhaust gas recirculation actuator failure
Ive no other fault codes for boost pressure / intake leak (Icarsoft)
Found the solenoid for the actuator, front left of the engine fairly well hidden, Tested the vacuum pipe and I could hear the vacuum escaping at the back of the engine, stripped everything down and ended up changing the actuator on the EGR as it was full of oil from the previously leaking cooler/ turbo feed pipe and the vacuum pipe was also a poor fit, fixed that pulled a vacuum and all was well, Problem solved I thought….. however I’m still getting the error
Does anyone know if there’s what I would call a ‘functional description or cause and effect’ document that shows where / how the flow through the EGR is measured and what the parameters are? Although I’ve yet to check the voltage / operation of the solenoid for the actuator im wondering if a sensor is on its way out?!? The MAP is showing a constant 98kp with the engine off at tickover or changing the revs
I’ve also got exhaust gas temp bank 1 sensor 2 showing 0 degrees c, which doesn’t sound correct
Again no other codes on the Icarsoft that I think are related, Wondering if I’m on a red herring with the fault code and it’s a knock on from a sensor somewhere that’s failing and not registered a fault yet???
All thoughts and input greatfully received!!
Andy 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #716081 13th Apr 2025 7:37pm
fisha
From the back of my mind:
I think that when the egr opens up, the system closes down the throttle body slightly, restricting air flow into the plenum and causing a pressure drop ( I presume to the plenum). This pressure drop I think helps suck exhaust gas through the egr and back into the plenum.
I have it in my mind that that its for this reason that you can’t just simply blank off the egr pipe feeding the intake as a method of disabling the egr on the more modern Euro 5/6 engines as the system can sense that when it closes down the throttle as part of the egr process it isn’t getting a matching pressure response due to the pipe being blanked.
So this would imply that for the egr flow a ton of stuff is monitored. Throttle , pressure before and after the throttle body, all the egr actuators, temp and exhaust gas etc V8 or else ...
Post #716088 14th Apr 2025 7:51am
Andyyav
Thanks Fisha it’s hard to know where to start as I don’t know what a healthy reading is.
The 2.0 ingenium gets this error when the DPF is knackered, the natural restriction of the DPF causes flow through the EGR, no restriction no flow hence the error, my exhaust tips aren’t sooty so I’m hoping mine is ok
Ill try find the DPF readings on the Icarsoft later but think I’ll have to get it in for some professional diagnostics 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #716090 14th Apr 2025 8:58am
Andyyav
Has some professional diagnostics carried out, EGR is capable of dropping the MAF reading however the actual and expected readings are inconsistent- suspected sticking EGR valve
There is an option to MAP it out without causing any DPF issues
I’ve decided (maybe foolishly) to change the EGR and clean the cooler out at the same time
So far it’s going well apart from some brittle pipe connections, I have hit one problem….im struggling to get the sideways bolts out of the cross over pipe bracket that go into the EGR, I can get a socket on but there’s not enough room to turn it, the crossover pipe stops an extension bar being of use and using it with a wobble / knuckle joint has proved fruitless.
Anyone know of a decent ‘short movement’ ratchet or have experience of getting them out?
the offending bolts -
1992 90 Exported
2016 L405 4.4 AB
Post #716524 21st Apr 2025 9:59pm
fisha
Why not a spanner with another extension spanner on the end of it ? V8 or else ...
Post #716527 21st Apr 2025 10:12pm
Andyyav
The spanner / Ratchet has to come off at an angle to miss the crossover pipe and ends up hard against the bulkhead, now considering cutting a spanner down or maybe a stubby Ratchet?? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #716528 21st Apr 2025 10:35pm
Andyyav
Got there eventually! Amazing what you can do with a cheap ratchet from the local hardware shop!
I think I buy something every time I work on the Fullfat Rolling with laughter
It’s off….. bit messy, cooler and EGR dont look too bad, start putting it back together in the morning once the coolers been cleaned
1992 90 Exported
2016 L405 4.4 AB
Post #716578 22nd Apr 2025 5:11pm
Andyyav
Anyone know if the oil and gunk under the oil/Egr cooler is ‘acceptable’ or do I have another issue?
1992 90 Exported
2016 L405 4.4 AB
Post #716703 24th Apr 2025 8:58am
Andyyav
Well all went back together and I was fault free for a while Big Cry
I’ve now done a DIY smoke test on the intake, EGRcooler and crossover pipe with out finding any issues, removed the 12v actuator switch for the cooler bypass all appears fine switched ok with 12v applied. In desperation I tried a different MAF sensor from a fiesta but again no joy, I’ve also added some rags into the bonnet where the intake is as I could hear it drawing air on acceleration again no change but it does take a while longer to register 3 failures and put the EML on, maybe I’ve disturbed some thing doing the smoke test. Who knows! 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #717656 9th May 2025 3:02pm
