![]() | Home > Technical (L322) > L322 4.4 TDV8 putting out clouds of white smoke at idle. |
Strobe84 Member Since: 21 Feb 2024 Location: Worcestershire Posts: 23 ![]() ![]() |
Hey. Did you ever get to the bottom of this? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 553 ![]() ![]() |
I know you've mentioned the fuel rail pressure drop, which leads you to think it's got a dripping injector, which would cause nearly all of your symptoms (except I'd expect the smoke to clear shortly after start-up as the excess fuel in the cylinder is burnt off).
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
D3Jon, No its not brake fluid but thanks for the suggestion. Rehab is for quitters!!!
Yes. I've got a similar issue with my 4.4... I've noticed that under certain conditions it smokes quite heavily then clears. It seems to be a mixture of blue, but mostly white "smoke" which I can't determine between steam and smoke. It seems to be that if it's been sat idling for a while, then I drive away, after a while it'll start doing it. If I don't idle it, it doesn't seem to do it... It doesn't idle rough, there's a slight "rattle" only heard from inside the cabin which we've put down to a small amount of chain slap but that's it. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3339 ![]() ![]() ![]() |
Strobe84 - That'll be your secondary turbo. Oil builds up in it as they idle or are driven gently and when you put your foot down and spool up the 2nd turbo it clears the oil as smoke.
I'm pretty certain I didn't spool the second turbo and it was still doing it. Also... Why white? Oil burn should be blue, no? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1539 ![]() ![]() |
No, oil burn is typically white. Used to be an easy way to tell if the timing on the older diesel engines was on its way out ... it would puff white.
Generally when engines burn oil, the smoke colour produced is regarded as grey or blue/grey. Not white.
I hate long threads that don't tell the end of the journey so here we go.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2757 ![]() ![]() |
Confirm that the drain valve in the bottom of the oil filter housing is complete and in place, because if not then the oil drains to the crankcase ventilation separator which cannot handle the oil flow so spits it into the primary turbo inlet tract giving the impression of a blown turbo oil seal. L405 D350 SE Carpathian Grey D5 19" rims |
Excellent and thanks GraemeS. Didn't know about that.
Many thanks for the update, very interesting read and good information ![]() Hope you get to the bottom of this issue, let's hope it's just the filter housing spring valve! ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 311 ![]() ![]() |
A top tip from Graeme and a really quick and easy job to check. 2012 Vogue TDV8 in Aintree green over sand |
When I replied to your helpful post I wasn't certain where this valve was located. In fact it's at the base of the oil filter which is also part of the oil cooler. The issue is we replaced the oil cooler with a new Nissans oil cooler unit so oil cooler, oil filter carrier and the drain valve are all brand new. Grasping at straws I'll try to get it checked over the weekend but am sadly doubtful. Damn, I was getting really excited at the thought it might not be the turbo. Come on surely someone has replaced the primary turbo on a 4.4 TDV8. Help please by sharing your experience of what the job was like to do along with any tips or shortcuts. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
