Home > Maintenance & Mods (L322) > Dent above rear wheel arch - is this area doubleskinned?
steve2347
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
2012 L322
I've managed to dent above the rear wheel arch on the body line and I'm looking for some advice.
I've spoken to someone for PDR and they suggested a body shop because they suspect that area of the body is doubleskinned. Does anyone know if this is the case?
I've tried accesing the panel from behind by removing the taillight insert, but there appears to be sound dampening blocking me.
Post #716199 16th Apr 2025 2:06pm
mjdronfield
Can’t actually answer as never done it, but can’t you get to it by taking the wheel arch liner out?
Been a while since I’ve been under mine, so might be wrong….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #716207 16th Apr 2025 4:32pm
pcourtney
watching with interest, as I also have a small dent on the drivers rear wheel arch Smile
Post #716209 16th Apr 2025 4:41pm
mjdronfield
Ah, found this pic in another post. Maybe you can’t then…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #716210 16th Apr 2025 4:42pm
JCW
You should just about be able to access this area from the inside, after removing all the radio / amp / DVD/ telephone etc modules, then the metal frames they mount into. from behind the trim - not too tricky if you’re relatively handy and methodical - take photos of the wiring routing as you go.
It’s a single skin in that area, however there may be foil backed bitumen anti-resonance material stuck on the inside which might hamper any PDR efforts, unless removed. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #716212 16th Apr 2025 4:48pm
Rawly
Hi
Have you considered dent devils ? I used them for the small job on my wifes car .
I didnt think they would have any luck but they did a great job
I think its a franchise company so they should have someone near you .
Good Luck
Rawly
Post #716216 16th Apr 2025 5:54pm
steve2347
Sounds like that is worth a try thanks. Just spoke to a technician whose done a lot of these before and he reckons it'll be a case of filling and repainting. SoI've nothing to lose by trying.
Post #716220 16th Apr 2025 7:16pm
steve2347
Thanks for checking, I did have a look earlier but with limited time I didn't find anything useful
Post #716224 16th Apr 2025 7:21pm
JCW
Looking at the dent, if reasonable access is achieved from the inside, a good PDR technician should be able to get that back to a decent finish Thumbs Up Jonathan
Post #716227 16th Apr 2025 7:37pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I'm pretty sure it is double skinned, in between is a sound deadening foam which is applied as a sticky backed pad before the outer panel is fitted. this pad then expands in the paint shop oven. So the space is pretty much completely filled in so tricky to remove. I got this from a series of programs showing how cars are made one of which was the new defender.
However if it was me I would cut an access in the inner arch big enough to give enough space to remove the foam and to deal with the dent. Then weld the cut out back in place, you would never know someone has been there.
Its my belief that this foam causes some of the bad rust we get, particularly in the leading edge of the arch, when it gets wet it holds the damp in place until the rust breaks through.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #716244 16th Apr 2025 9:55pm
JCW
I’ve repaired this area previously on a few L322’s and it’s a single skin. Jonathan
Post #716252 17th Apr 2025 7:29am
steve2347
Managed to get behind the dent this afternoon. Luckily it was behind the subwoofer, and I was able to get that out easily enough following this handy video from Sam's Motor & Machine
It's quite hard for me to tell if this is a single skin or not as I'm unable to see the outside of the car when I poke around the inside.
I'm also not easily able to see the crease that's visible on the outside, but it's possible that it hasn't actually pushed through. When you run you finger over it on the outside you can't feel anything, so it could be superficial.
If it is a double-skin, would it potentially be a good idea to cut out a small section of the internal side and then use that for access?
Otherwise, if I'm able to determine that it's single skin I'll see if there are any PDR guys willing to work on it with questionable access.
Post #716280 17th Apr 2025 2:40pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Unless it's a shadow or something if looks like you can see the dent on the inside. I very much doubt its double skinned and it's already been said it's not by someone who's done repairs in that area. I can confirm it's not double skinned at the rearmost edge / corner, by the tailight on the same panel. I pushed a nasty dent out of there with a portadown very easily ( followed by some hammer & dolly work) and guess the same could work on this one. I'm very interested in the outcome here as I have a rusty arch to repair when I can summons up the courage to pull the electronics out for access!
Chris
Post #716286 17th Apr 2025 3:55pm
steve2347
Looking at the photo I posted the shadow to the left of the dent is the crease, and the more I look at the photos I'm sure it's a single skin as others have said.
I've emailed the photos to someone but they haven't got back to me yet. If I can get a reasonable quote I'd prefer a professional take care of it as I'm not usually patient and delicate enough for this kind of work.
Pretty chuffed it doesn't require filling and repainting!
Post #716300 17th Apr 2025 7:25pm
steve2347
Any recommendations for DIY tools?
All the PDR people I've contacted have either not got back or recommended someone else that didn't respond.
Tried using a hairdryer and some thin glue sticks but that was pretty pathetic Sad
Post #716736 24th Apr 2025 7:11pm
