Home > Maintenance & Mods (L405) > Park Assist using IidTool
Having successfully enabled Dynamic mode, I’ve been “experimenting” with getting Park Assist working. I’ll probably never use it but it’s just a challenge to get it working.
I’ve now got the Park Assist icon beside the PDC icon but when I press it, the orange LED just flashes and the PA screen doesn’t appear.
I was thinking that since I have the 360 PDC cameras and sensors, I didn’t need any more hardware but I’m wondering if I’m missing some additional hardware to get this working?
Cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #716583 22nd Apr 2025 5:50pm
Well, I got it working!
CCF settings to follow if anyone else is interested?
Post #716854 26th Apr 2025 7:06pm
I'm very interested, like you, I'll only use it once to play but it's nice to have it... So please list the CCF mods, cheers... Thumbs Up Pete
Post #716858 26th Apr 2025 8:26pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
I wonder if this will work on the 2016 model? 2016 4.4 diesel
Post #716898 27th Apr 2025 2:20pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Use it now and again , it’s pretty good tbh. 2019 SV AB Dynamic Scafel Grey
Post #716899 27th Apr 2025 3:02pm
First off, you need to check you have the full compliment of sensors (10), which means you need to have them in the sides of the front and and rear bumpers. If you don’t have them, there are a few threads online that document what you need to buy (sensors and cable loom). I think most Autobiography models will have them already fitted.
I had a chat with Patrick from GAP over email and he confirmed these settings, because when I first tried this, it didn’t seem to work but he said it can take the car quite some time to relearn the new CCF file, so you might need to be patient.
Park Assist
T5-042 Pdc Set to 10 Channel fitted ( Park Assist) (0x4)
EUCD-026 Power Steering Type Set to Electric Power Steering with external angle and torque control , only for JLR
EUCD-059 Parking Assistance Set to PDC (360) – Parking (Parallel, Perpendicular, Exit)
EUCD-140 Pdcautoactivationmenu Set to With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation Set to Default OFF configurable
MultiCAN-602 PDC Set to 10 Channel fitted ( Park Assist)
MultiCAN-658 ParkAssistHMI Set to Low Line HMIMy D5 does not have the surround camera system. Low Line HMI works for me, but might be High Line Dynamic with surround camera
After making these changes:Menu–Service/Test -> PAM-Parking Aid -> Reset CCF Learn
Menu–Service/Test -> Reset Vehicle
Menu–Service/Test -> IPMA-Image Processing Module ‘A’ -> Allow Central Configuration Data Learning
Menu–Service/Test -> IMC-Infotainment Master Controller -> CCF Relearn
Good luck Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #716909 27th Apr 2025 5:32pm
Thanks for that..... Thumbs Up Pete
Post #716951 27th Apr 2025 11:47pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
interesting ....
Post #716958 28th Apr 2025 5:56am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
could this work for a 2018+?
Post #716964 28th Apr 2025 8:24am
I’m not sure if this will work on MY18 onwards. I do know that the way it displays is different but fundamentally it’s the same system.
I would imagine it will work on previous years as well.
I guess if you have the sensors, you can try it but obviously it’s your call at the end of the day, I accept no responsibility for any issues. Got - 2017 SDV8 Autobiography in Loire Blue
Post #716965 28th Apr 2025 8:41am
adara
The sensors exist, the settings in my CCF are:
T5-042 Pdc - 8 Channel fitted
EUCD-026 - Power Steering Type Set to Electric Power Steering without external angle and torque control, only for JLR
EUCD-059 - Parking Assistance Set to PDC (360)
EUCD-140 - Pdcautoactivationmenu Set to With PDC Auto Activation menu
MultiCAN-469 - PDCAutoActivation Set to Default OFF configurable
MultiCAN-602 - PDC Set to 8 Channel fitted
MultiCAN-658 - ParkAssistHMI High Line Dynamic
I guess I'll give it a try, thank you.
Post #716966 28th Apr 2025 8:49am
The one setting I had to change is this one - MultiCAN-658 - ParkAssist"HMI High Line Dynamic" but this might be the correct setting for later MY cars. When I set it to that value, it doesn't work, so I used" Low Line HMI"
Remember to do all the resets and relearns Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #716973 28th Apr 2025 10:07am
adara
Thank you, thank you, I can confirm that the instructions worked for my car too! I have the blue P icon in the dashboard and the Park Assist option in the central screen.
It worked with MultiCAN-658 - ParkAssistHMI High Line Dynamic.
On the other hand, the function itself isn't very sensitive or advanced (you still need to change from forward to reverse yourself)...
Now, if I could find the mod for adaptive cruise...
Post #716978 28th Apr 2025 1:28pm
Great result! Glad it worked for you Thumbs Up
It's not the most sophisticated system but it's cool to watch it in action
My car already has adaptive cruise but I think that needs a lot more work to get working
https://www.fullfatrr.com/forum/post557899.html Got - 2017 SDV8 Autobiography in Loire Blue
Post #716981 28th Apr 2025 2:14pm
As a matter of interest my 2014 Autobiography SDV8 only has 4 PDC sensors in each bumper, none in the sides so I guess I can't do it as I'm not spending money to have it...!! Pete
Post #716991 28th Apr 2025 3:57pm
