![]() | Home > Maintenance & Mods (L405) > Park Assist using IidTool |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Well, I got it working!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I'm very interested, like you, I'll only use it once to play but it's nice to have it... So please list the CCF mods, cheers... |
Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 207 ![]() ![]() |
I wonder if this will work on the 2016 model? 2016 4.4 diesel |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
Use it now and again , it’s pretty good tbh. 2019 SV AB Dynamic Scafel Grey |
First off, you need to check you have the full compliment of sensors (10), which means you need to have them in the sides of the front and and rear bumpers. If you don’t have them, there are a few threads online that document what you need to buy (sensors and cable loom). I think most Autobiography models will have them already fitted.
Thanks for that..... |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
interesting .... |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
could this work for a 2018+? |
I’m not sure if this will work on MY18 onwards. I do know that the way it displays is different but fundamentally it’s the same system.
The sensors exist, the settings in my CCF are:
The one setting I had to change is this one - MultiCAN-658 - ParkAssist"HMI High Line Dynamic" but this might be the correct setting for later MY cars. When I set it to that value, it doesn't work, so I used" Low Line HMI"
Thank you, thank you, I can confirm that the instructions worked for my car too! I have the blue P icon in the dashboard and the Park Assist option in the central screen.
Great result! Glad it worked for you |
As a matter of interest my 2014 Autobiography SDV8 only has 4 PDC sensors in each bumper, none in the sides so I guess I can't do it as I'm not spending money to have it...!! Pete
