![]() | Home > In Car Electronics (L322) > DAB radio module |
| Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155
I have this unit: https://www.in2digi.com/products/d-jv-2/ It's working for 6 years now without any problems. |
| Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87
I'd been looking at the Indigi2 but thought it was very expensive. How have you found it, was fitting it a faff or was it relatively straight forward? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310
Hi Beullie - went DAB module hunting this afternoon, but didn’t spot one. Can you give me any further guidance based on this pic ?
| ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 52
Thanks Ash - so a bit of dismantling needed then ? |
Yes thinking about it it is behind that area I market bit of a fiddle need three hands but easy when you get in there 2012 Westminster 4.4 tdv8 |
Forgot to update this. DAB+ installed and working perfectly. Needs the slight tweak to select DAB on the head unit, but that’s the case for all L322 & L320 models. |
| Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154
Jonny,
You need a DAB+ module - they go for anything between ÂŁ100 and ÂŁ250 on eBay. You then splice in the connector to replace the existing power lead and you have DAB+.
Can anyone give me the part number for the DAB+ module to upgrade from the DAB one please?
| Vigilo Member Since: 27 Apr 2025 Location: Nottingham Posts: 10
Hi - from my notes (not fitted this yet - car is still in the garage being welded...ho hum)
It’s the CPLA 14F720 that’s the important bit. The BM relates to firmware version, so don’t necessarily hold out for a BM if you can get a working version with a different last 2 letters code, although it should be B something as the B denotes it as a DAB+ module.
I found the patch lead is about ÂŁ30 (and 'challenging' to find as JonnyCJ says)
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 709
Hi,
| All times are GMT |
