![]() | Home > In Car Electronics (L322) > DAB radio module |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 153 ![]() ![]() ![]() |
I have this unit: https://www.in2digi.com/products/d-jv-2/ It's working for 6 years now without any problems. |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 87 ![]() ![]() ![]() |
I'd been looking at the Indigi2 but thought it was very expensive. How have you found it, was fitting it a faff or was it relatively straight forward? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 269 ![]() ![]() ![]() |
Hi Beullie - went DAB module hunting this afternoon, but didn’t spot one. Can you give me any further guidance based on this pic ?
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 51 ![]() ![]() ![]() |
Thanks Ash - so a bit of dismantling needed then ? |
Yes thinking about it it is behind that area I market bit of a fiddle need three hands but easy when you get in there 2012 Westminster 4.4 tdv8 |
Forgot to update this. DAB+ installed and working perfectly. Needs the slight tweak to select DAB on the head unit, but that’s the case for all L322 & L320 models. |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
Jonny,
You need a DAB+ module - they go for anything between ÂŁ100 and ÂŁ250 on eBay. You then splice in the connector to replace the existing power lead and you have DAB+.
Can anyone give me the part number for the DAB+ module to upgrade from the DAB one please?
Vigilo Member Since: 27 Apr 2025 Location: Nottingham Posts: 9 ![]() ![]() ![]() |
Hi - from my notes (not fitted this yet - car is still in the garage being welded...ho hum)
It’s the CPLA 14F720 that’s the important bit. The BM relates to firmware version, so don’t necessarily hold out for a BM if you can get a working version with a different last 2 letters code, although it should be B something as the B denotes it as a DAB+ module.
I found the patch lead is about ÂŁ30 (and 'challenging' to find as JonnyCJ says)
