Home > Maintenance & Mods (L322) > High Pressure pump
Balloonengineer
High Pressure pump
Hi All
My 2012 4.4 tdv8 died on the motorway last night, and now trying to find out what's wrong with it, as my GAP tool says there are no faults!
My guess is no fuel from the high pressure pump as the fuel rail pressure is much lower than the expected pressure both those from live data on the GAP
So the question is, any other suggestions!? Starter turns over, but no start and no faults! Im fairly sure the tank pump works as the bleed on top of the filter squirts. Any idea what that bleed pressure should be?
Has anybody here changed the high pressure pump, and is there a workshop procedure, or any other hints and tips, or is it just a straight unbolt and bolt on a new.
Anybody else suffer from this and is this common at only 86K miles?
Thanks
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #716900 27th Apr 2025 3:48pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Pump ideally should be timed using JLR special tooling, engine at TDC, fit special tooling to pump, use guides to slide pump home. It's documented in my thread "All I Want for Christmas". L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #716902 27th Apr 2025 4:10pm
toby1
It should have around 5 bar from the filter pressure port. There are a few threads on the internet with crank no start after a replacement HPFP, but they've never been finished with the fix.
I also have crank no start with no fault codes after replacing the pressure sensor and one fuel pipe.
It needs a minimum of 150 bar to start. 2012 Vogue TDV8 in Aintree green over sand
Post #716912 27th Apr 2025 5:46pm
cass
I'd start with the Cheap/Easy things first, have you checked it has got fuel in? - sounds stupid but you wouldn't be the first to get caught out like that.
Could someone have put petrol/Adblue in it?
Post #716929 27th Apr 2025 7:39pm
Balloonengineer
Yes, I have checked it has correctly filled fuel and plenty of it.
Like others, I have done all the obvious stuff. Obviously others have had the same problem, but as somebody mentioned the fixes haven't been publicised Previously......
Post #716931 27th Apr 2025 7:57pm
Balloonengineer
Hi Chaps, so an update
Tried a few times this morning so see if it miraculously cures overnight, well it is Easter.
Doesn't start.
Made a fuel pressure adapter to fit to fuel filter bleed. 4.5 bar output, maybe slightly low from ideal, i'm not sure?
Still no start
Work this out!
Sprayed ice freezer spray on high pressure fuel pump area, and it now starts and runs fine. Gave it half an hour to regain the engine bay temperature. And it still starts.
Going to work shortly (without it) , so will try it again tonight, and tomorrow morning and report back to see if it still starts.
Now, are there any sensors attached to the HPFP, or any other ideas as to what's going on?!! Previously......
Post #716982 28th Apr 2025 2:43pm
toby1
The pump has a fuel temperature sensor and a metering valve. It is all in the workshop manual in the wiki.
What made you think to use the spray? I've never heard of it before.
IIRC 4-7 bar is an acceptable range. How did you make the adaptor please? 2012 Vogue TDV8 in Aintree green over sand
Post #717025 28th Apr 2025 9:28pm
Balloonengineer
Freeze spray can temporarily fix dodgy electronic components. I sprayed the general pump area, in hindsight I should have been more specific on where I sprayed if knew a bit more about the pump and whereabouts of the sensor locations
Lets see what happens tomorrow. I guess I will add a can to the extensive travelling roadside tool kit
To make the adapter its 7/16 UNF (on the filter) to 1/4 NPT (for the gauge), so got a bit of nylon rod, (but could have been any material to hand) and tapped each end, its very simple. I can do a pic when I get 5 minutes. You have to unscrew the Schrader valve core a bit for fuel to pass through, and an old towel underneath to catch the spills. Pressure gauges are only a few pounds for a 10 bar one as fitted to a welding regulator. Previously......
Post #717034 29th Apr 2025 12:11am
toby1
OK, great. Thank you. 2012 Vogue TDV8 in Aintree green over sand
Post #717039 29th Apr 2025 7:31am
Balloonengineer
As requested pics attached of my home made fuel pressure gauge. Don't forget to slacken the schrader valve core!
So the cranking update is,
It started this morning and this evening, so will gradually build up the mileage to regain the confidence it won't stop again.
But don't yet know what the definitive problem was.
 Previously......
Post #717104 29th Apr 2025 8:38pm
toby1
Yes, it is an odd one.
Thank for the pictures and fingers crossed. 2012 Vogue TDV8 in Aintree green over sand
Post #717111 29th Apr 2025 9:00pm
Balloonengineer
A useful resource??
https://gershon.ucoz.com/LANDROVER/RANGEE/...DIEZEL.pdf Previously......
Post #717292 2nd May 2025 10:57pm
