![]() | Home > Maintenance & Mods (L322) > High Pressure pump |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 456
Pump ideally should be timed using JLR special tooling, engine at TDC, fit special tooling to pump, use guides to slide pump home. It's documented in my thread "All I Want for Christmas". L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
| toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 315
It should have around 5 bar from the filter pressure port. There are a few threads on the internet with crank no start after a replacement HPFP, but they've never been finished with the fix.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I'd start with the Cheap/Easy things first, have you checked it has got fuel in? - sounds stupid but you wouldn't be the first to get caught out like that.
| Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180
Yes, I have checked it has correctly filled fuel and plenty of it.
Hi Chaps, so an update
The pump has a fuel temperature sensor and a metering valve. It is all in the workshop manual in the wiki.
Freeze spray can temporarily fix dodgy electronic components. I sprayed the general pump area, in hindsight I should have been more specific on where I sprayed if knew a bit more about the pump and whereabouts of the sensor locations
OK, great. Thank you. 2012 Vogue TDV8 in Aintree green over sand |
Yes, it is an odd one.
A useful resource??
| All times are GMT |
