Home > General > What Did You Do In Your Full Fat Today
Page 382 of 385 <123 ... 381382 383384385>
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Clicked over 100,000 miles today in my MY2012 - 40,000 of which are mine and I’ve enjoyed every one of them.
Post #716110 14th Apr 2025 8:25pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Had the underneath totally cleaned, heat shields etc removed, any surface rust converted with Fertan and then when that had dried, all exposed surfaces were sprayed with Dynax UC, cavities, inside of subframes etc liberally sprayed with Dynax S50.
Post #716150 15th Apr 2025 2:54pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
I had my oil leak sorted along with a few other issues. My leak was the oil cooler so it was replaced. The coolant reservoir was flushed but for some reason the float wouldn't do what it was born to do. I wasn't going to live with a constant low coolant warning so I asked the garage to just change it too.
My headlight washers were not working,turned out the high pressure squirty pump also decided to cease doing its job. Same with the rear window washer pump.
The garage also spotted worn upper suspension bushes at the back and so they were changed out.
Refill of coolant and fresh oil and filter and good to go.
I have also had to order up a passenger side rear knuckle. Found one by NTY on eBay for £125. It appears genuine LR part is rare / possibly extinct and around £600 if you find stock.
Post #716177 15th Apr 2025 10:55pm
JonnyCJ
Picked up the car after 2 weeks in the garage whilst I was on hols. They’d wire brushed the whole of the underside where there was any rust and then applied Fertan rust converter. Once cured the whole of the underside was sprayed with Dynax UC in 2 coats. Dynax S50 was applied liberally into any cavity, including subframes and sills. This is one Rangey that isn’t going to go rusty !
They also fixed the 30mph warning, which was a broken wire at the rear. Unfortunately a new front offside ride height sensor was needed as they couldn’t get the suspension re-calibrated with the old one.
Got it home and then treated it to a new genuine LR diesel fuel filter and changed the oil and filter.
A very good day all in all.
The old girl now sounds very sweet and popped her on an overnight battery charge for good measure, as she’s not done many miles for a couple of weeks.
Post #716675 23rd Apr 2025 8:58pm
JonnyCJ
Swapped out the rotary gear selector surround trim for a new item. It’s the large aluminium coloured bit and it was pitted and marked from 1000+ careless dropping of keys into the central cup holder area.
A 15 min job which took 2,hrs. That was only because I decided to do a deep clean on the whole centre console area, including handbrake switch area, height and terrain buttons surround etc etc.
It was actually pretty simple to do and very satisfying. All because I changed the gear selector topper.
It’s funny how renewing one small part shows up the rest of it.
The piano black console side trims have been left off as they need a polish now.
Where will it end I ask myself…
Post #716745 24th Apr 2025 8:15pm
knotty68
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
New wipers front and rear.
Fitted interior LED bulbs.
Removed swollen wheel nuts and fitted new ones, click click to 140NM.
Ultrasonic-ed the original locking wheel nuts, but will not re-use.
Began wiring up a trailer plug to use with Ctek charger, but realised I had a 12N plug and needed a 12S, return and repurchase done.
Fitted OE rubber mats front, rear and cargo. Ebay!
Fitted OE dog guard. Ebay!
Not quite brave enough to try to replace the under wing mirror units yet. Seem to require a LOT of force? Any tips?
Post #716855 26th Apr 2025 7:14pm
knotty68
Sewed on a surprisingly acceptable Aliexpress steering wheel cover which was tedious, but satisfying.
Removed the glovebox to fit LED bulb, lost the spring for the latch switch, so doesn't matter what bulb is in there. Any thoughts on replacement size?
Tried to remove the Westfalia trailer hitch socket to be able to use the 2" square socket, but that's not coming out of there anytime soon. Any advice?
Replaced the bonnet struts, world of difference.
Replaced rear hatch struts, amazing.
Wired up trailer plug to use CTek, plugged in, no errors, not sure I need it but nice to have for when I do.
Thought about adding Navtool, but need to review fitment 'instructions' and a brave pill.
Post #716923 27th Apr 2025 6:39pm
knotty68
Drove to four different locksmiths to get a couple of blanks cut for key fob upgrade.
Fitted the led wing mirror puddle lights. Thanks to SeldomSeenKid for the tip. Perfecto.
FOUND the aforementioned spring from the glovebox light switch!
Investigated the passenger footwell and under dash panel ahead of Navtool installation.
Fitted private plate after cleaning up previous numerous sticky pads.
Fitted a Brodit ProClip and Holder for iPhone and pondered charging cable routing.
Post #717003 28th Apr 2025 5:35pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Did an oil change, didn't seat the o-ring properly, dropped a litre of oil all over the underside of the car and no doubt on the road behind me Embarassed .
Lesson for the day: check you have no oil leaks before setting off after an oil change, on the plus side, it is unlikely to rust anytime soon... Very Happy
Post #717404 4th May 2025 9:08pm
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Changed a very, very seized wiper arm with a new oem one, not cheap it turns out. Pain in the bum to refit the spoiler in my case (seemed easier for everyone I watched on YouTube).
Also it’s not fixed my broken rear wiper spray as I hoped it would…
 2009 pre-facelift 3.6 TDV8.
Post #717513 6th May 2025 7:00pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
MOT today, amazingly passed with no advisories again.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #717615 8th May 2025 4:33pm
Vigilo
Took it to get an estimate for bodywork repairs.
Rot in the rear door at the bottom and need the plastics off along the body sills to inspect.
Chap at the garage pointed out filler in the R/N/S wing I'd not noticed so rear bumper off too.
Fingers crossed its not to extensive, but better done than left Some days its just not worth chewing through the restraints.....
Post #717640 9th May 2025 8:03am
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Who said the split tailgate is for posh picnics at the polo...
PS not strictly today but came across this when clearing my phone and it makes me smile. I love our car, shame as lately it's been suffering major turbo issues that might spell the end MY11 Vogue 4.4 TDV8 - "African Queen"
Post #717650 9th May 2025 12:09pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I drove the car to the garage to have the rear ACE pipes replaced. It was the first time I had driven it in nearly 3 weeks. It was so nice to have the easy power of the V8 and the auto again, compared towhee I have been driving in the last 2 weeks.
Post #717666 9th May 2025 9:58pm
hmallett
I drove my car back from the garage, after having rear ACE pipes replaced, along with rear brake flexi pipes. It felt good to be back in the car.
However, not only was I £1767.44 lighter, but the garage also identified that the parking brake actuators are both cracked. So that's another job.
And yet I still enjoyed driving the car again.
Post #717903 13th May 2025 11:44pm
