Home > Maintenance & Mods (L405) > l405 battery
Page 8 of 8 <12345678
AnnualMan
Switzerland
Hmmm….my main 12v is under the boot floor and the auxiliary is behind the right side panel further forwards (closer to the seat backs). Perhaps yanking isn’t the right method for my car? 2025 P550e AB
Post #706702 12th Dec 2024 3:58pm
start the 'yank' on the bit nearest the seats then work your way along to the tailgate... ... - .- -.
Post #706705 12th Dec 2024 4:26pm
Gremlin500
Ummmm, I do mine the other way, it’s easy to get your fingers up inside that vent/grille thingy & pull down & out, there are 3 clips along the top edge, see WM manual:
Try to pull close to where the clips are, so as not to do any damage, they do take a fair heave, try not to worry about it.
Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #706709 12th Dec 2024 5:13pm
Gremlin500
OT warning: old wartime joke about British girls wearing American knickers: one Yank and they’re off!
(Sorry Stan, I’ll take the fine Embarassed ) V6 Vogue - “Less is More” - less to go wrong!
Post #706710 12th Dec 2024 5:16pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Alistair wrote:
The Exides are physically an exact match for the OE batteries for my MY and a very straight swap.[/img]
I wish I had bought an Exide battery - I bought a Bosch battery for my auxiliary battery, as it has a longer warranty, but the breather pipe location interferes with the bracket, which is really annoying.
Post #714564 21st Mar 2025 12:19pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
When I replaced my battery. I drilled a hole in the clamp bar. Shown on page 4 of this thread.
I was not happy at first but when I next need to replace the battery. I am not limited. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #714566 21st Mar 2025 1:04pm
ash83
United States
So, some models have a capacitor instead of a 2nd battery?
I have a V6SC 2019 HSE.
On the right side of cargo there’s an indent where the battery is on older models.
Anyone have a pic where they’re located on 2018+?
Post #717035 29th Apr 2025 2:16am
ash83
United States
I pulled the panel. Clearly it had never been removed because, damn, those clips were tight! Really had to yank it.
No secondary battery on my car.
Post #717130 30th Apr 2025 4:26am
Gremlin500
My MY17 V6 has stop-start but no aux battery or capacitor!
I turned stop-start off permanently, it’s a stupid idea, it wears out the battery, the starter motor, and significant engine wear happens during starting, why anyone would want it mystifies me…
I wonder, when JLR introduced stop-start, did they beef up the starter motor components, or are the pre and post motors gears the same old thing? Knowing JLR bless them, I suspect I can guess the answer! Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #717143 30th Apr 2025 10:06am
are you 100% you dont have a capacitor...
will look like this,
[the arrow points to the signal wire removal] ... - .- -.
Post #717145 30th Apr 2025 10:42am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I think my battery or batteries are on their way out. On some brand of cars with dual batteries, they should be removed and replaced in a particular order, is that not the case with the L405?
Cheers
Post #718589 26th May 2025 6:04am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I was not aware of any articular being required when I replaced both of mine. I did them both at the same time and if I remember correctly I did the RHS one first and the one under the spare wheel second. Connected all up and told car about new batteries and all was good.
The only thing that I didn't realise was that disconnecting the batteries triggered my tracker and I got a phone call asking me if I could still see my car, which was in front of me with most of the boot in bits! Rolling with laughter _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #718609 26th May 2025 11:26am
Richie N
Thanks 👍
I tested mine today and auxiliary appears to be ok, the main one not so good..
I’ve ordered a Yuasa YBX9019 from tanya.co.uk
Post #718621 26th May 2025 3:16pm
