![]() | Home > Technical (L322) > DPF regen on 4.4 TDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 936 ![]() ![]() ![]() |
You need at least a half tank of diesel for the DPF cycle to kick in, and maintain a steady 55 to 70mph on the motorway for the car to even think about doing a regen ( that is providing everything is working as it should be - no air leaks on hoses etc etc )
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 254 ![]() ![]() ![]() |
Useful - thanks. Exactly what am I looking at on the GAP tool ? presumably under Live Data or whatever it's called ?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
It is not the rev level that initiates a regen but the soot level. you get a yellow restricted power warning at c.19 and a red when it gets to around 27 (may need confirmation).
Thanks Dolphin - so effectively, just drive around as normal and if it decides it needs to regen it'll do it if it can and if it can't it'll let me know ?
yup. drive normally so if you start getting RP (restricted power) warnings, then you have an air leak in a pipe or inlet manifold. |
JAD Member Since: 19 Oct 2020 Location: Wirral Posts: 34 ![]() ![]() ![]() |
I live on the Wirral Jonny, My amber DPF warning came on in Liverpool city centre the other day. Drove through the Wallasey tunnel and down the M53. By the time I got to Clatterbridge the light had gone out. I normally stick between 60-70mph.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
You don't need high revs for a DPF regen on these vehicles. Post CAT EGT's will be 600+ degrees at a steady 60mph in 8th gear. High revs are not required.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
High revs are not needed, and i think potentially could discourage the regen process. You need the engine to be in a situation where:
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 233 ![]() ![]() ![]() |
I do quite a bit of green laning in mine low revs in low box and I’ve never had a problem with it doing a regen. Never had an amber or red warning. Did a 3 day coast to coast last week with no issues with DPF at all. Just drive it and enjoy it. |
Plugged in my GAP today and did a run up the motorway for 20 mins or so at a steady 60.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
If you search there's a huge DPF thread which has incredible detail within it , it has all the answers you need |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 130 ![]() ![]() ![]() |
Yes, this is the thread.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 106 ![]() ![]() ![]() |
Current version of Gap have it on (dynamic regen) , mine does when i updated and changed the license to me last year on the 2nd hand one i bought . |
I'm pretty sure that 'Remaining volume' always reads zero when using the GAP IID tool.
