Home > Technical (L322) > DPF regen on 4.4 TDV8
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Given the 8 speed gears on the later 4.4s to my mind, the revs don’t get that high even on a motorway run to get the cat hot enough for a regen. Am I correct or does the Rangey have a different system to more normal cars when it comes to to regeneration?
Post #717068 29th Apr 2025 2:00pm
pcourtney
You need at least a half tank of diesel for the DPF cycle to kick in, and maintain a steady 55 to 70mph on the motorway for the car to even think about doing a regen ( that is providing everything is working as it should be - no air leaks on hoses etc etc )
I use a GAP IID and my iPhone to see how it is working, takes about 15 to 20 mins to get it back down to low 3's or 4's
The EGT ( Exhaust Gas Temp ) Bank 1 using Sensor 2 is vital, in normal driving it can read anything from 150 to 250 deg, but when the regen kicks in it shoots up to 600 degrees +
Post #717071 29th Apr 2025 2:33pm
JonnyCJ
Useful - thanks. Exactly what am I looking at on the GAP tool ? presumably under Live Data or whatever it's called ?
Low 3 or 4's - is that gm's of soot ?
Post #717075 29th Apr 2025 2:49pm
Dolphinboy
It is not the rev level that initiates a regen but the soot level. you get a yellow restricted power warning at c.19 and a red when it gets to around 27 (may need confirmation).
Speed is also irrelevant. I've had it go at 30 mph but it is advised to do a minimum of 50mph in order to negate the chances of a fire at the high temps. Shocked
To initiate a regen it pumps fuel into the exhaust to raise the temp to c.600.
Look under live values. You can tick up to 6 (or 8?) values to monitor on the same page. go for temps and soot level definitely.
Post #717151 30th Apr 2025 12:06pm
JonnyCJ
Thanks Dolphin - so effectively, just drive around as normal and if it decides it needs to regen it'll do it if it can and if it can't it'll let me know ?
Another uneducated question - does it regen frequently if conditions allow, or only when getting full ?
Post #717157 30th Apr 2025 1:25pm
Dolphinboy
yup. drive normally so if you start getting RP (restricted power) warnings, then you have an air leak in a pipe or inlet manifold.
Post #717175 30th Apr 2025 7:19pm
JAD
United Kingdom 2012 Range Rover Vogue TDV8 Epsom Green
I live on the Wirral Jonny, My amber DPF warning came on in Liverpool city centre the other day. Drove through the Wallasey tunnel and down the M53. By the time I got to Clatterbridge the light had gone out. I normally stick between 60-70mph.
It's done it about 3/4 times in the 3 years I've owned the car and I normally take it down the motorway from Prenton and it always goes out around Vauxhalls/Ellesmere Port.
I just turn around and come back then.
The car gets mostly local short journeys with the occasional long trips towing our caravan which is why I guess its coming on!
Post #717376 4th May 2025 1:59pm
D3Jon
You don't need high revs for a DPF regen on these vehicles. Post CAT EGT's will be 600+ degrees at a steady 60mph in 8th gear. High revs are not required.
The exhaust gas temperatures are raised by the additional fuel being injected on the exhaust stroke, that fuel makes it's way to the CAT (which is located before the DPF) and an exothermic reaction takes place where that extra fuel is effectively burned. These high temps facilitate the DPF regeneration.
I know that some static (i.e. stationary in a workshop) regens on other makes, call for the revs to be held reasonably high, BMW's for example. I'm not personally a fan of regens being carried out on a non-moving vehicle due to lack of cooling air over components during the process.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #717385 4th May 2025 3:11pm
fisha
High revs are not needed, and i think potentially could discourage the regen process. You need the engine to be in a situation where:
- its under light(ish) load so that fuel is being delivered to the engine (as opposed to idle, or over-run downhill)
- there is spare overhead to deliver more fuel than is actually needed for that light load
If you're high-revving the engine, you may be taking away the spare overhead to add more fuel. This is why driving normally above 40mph is best for the regen ... its where you typically drive along with a light throttle. V8 or else ...
Post #717406 4th May 2025 9:19pm
PeteT80
I do quite a bit of green laning in mine low revs in low box and I’ve never had a problem with it doing a regen. Never had an amber or red warning. Did a 3 day coast to coast last week with no issues with DPF at all. Just drive it and enjoy it.
Post #717431 5th May 2025 10:52am
JonnyCJ
Plugged in my GAP today and did a run up the motorway for 20 mins or so at a steady 60.
My DPF soot level shows 30.2 and didn’t move at all. The capacity left was showing at zero.
No warning lights and half a tank of fuel. Am I looking at the correct parameters for this ? Still new to GAP, so don’t really know what I should be reading and do I need to reset any parameters before logging ?
Post #717956 15th May 2025 9:52am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
If you search there's a huge DPF thread which has incredible detail within it , it has all the answers you need Thumbs Up plus you can email Pat @ GAP and ask him to give you access to manually initiate re-gen function on your IID tool. It used to be a BETA function only , i've no idea if the current versions of the tool have this installed these days as I run a petrol engine . 2019 SV AB Dynamic Scafel Grey
Post #717958 15th May 2025 10:26am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Yes, this is the thread.
https://www.fullfatrr.com/forum/topic60839.html
Post #717959 15th May 2025 10:42am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Current version of Gap have it on (dynamic regen) , mine does when i updated and changed the license to me last year on the 2nd hand one i bought .
Post #718124 17th May 2025 10:05pm
D3Jon
I'm pretty sure that 'Remaining volume' always reads zero when using the GAP IID tool.
DPF soot level of 30.2 seems high though for a TDV8, and the car should be requesting a regen by now.
My TDV6 Disco 4's soot level always gets to just over 30 before a regen is demanded by the ECU. Can't remember what level it's demanded on the TDV8 (been almost 2 years since I sold mine) but 23 seems to ring a bell without looking it up.
Do a bit more driving, join a dual carriageway and give it a good boot-full down a slip road, then drive at 60+ mph and a regen should occur.
If not, you might consider running a manual regen via your GAPIID tool, whioch you can monitor.
2014 Disco 4 HSE
Post #718130 17th May 2025 10:37pm
