![]() | Home > Technical (L322) > Steering wheel groan |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Hi all
It sounds the same as the the noise you get if you rub your thumb over the leather seat. Odd FFRR TD6 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
is the steering affected in any way greg? ... - .- -.
Nope, steering feels fine. Had the column replaced 1 month ago. Wondering if it could be something to do with that. FFRR TD6 HSE
just wondering if its a piece of trim rubbing... ... - .- -.
i dis-abled my steering movement and started to get this noise, enabled the movement and it seems to have gone...i'm none the wiser why it was happening.. |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
I would suggest that it could well be the wheel rubbing against the trim. As it was replaced recently, maybe the trip wasn't put back together perfectly.
Thanks Mikey
