![]() | Home > Technical (L405) > Range sdv8 doesn't go over 2000rpm.and shut down |
Jass786 Member Since: 29 Apr 2025 Location: Birmingham Posts: 20 ![]() ![]() ![]() |
Hi
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8683 ![]() ![]() ![]() |
Sorry, can't see anything of note on that video, only shows the dials for a second and camera is moving too fast...
Hi
Now clear them all and see what comes back... |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 676 ![]() ![]() ![]() |
There's a lot going on there so I'm guessing some kind of bus failure or water in the loom / damaged loom or just control bus gone crazy.
Might find some help here...
https://streamable.com/f894tr
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1379 ![]() ![]() |
With all that going on
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 351 ![]() ![]() ![]() |
Fault finding with the air intake system removed isn't going to help as straight away your'e going to have correlation errors between the MAF and MAP sensors detecting wildly different values. Speed control would be my first port of call, and yes it earth's under the drivers side wheel arch. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Hi can't find speed control under driver side arch thanks |
The earth point for this and the abs module are connected to an earth stud under the drivers side wheel arch and is a common failure.
