![]() | Home > Maintenance & Mods (L322) > Aggravating Wheel Wobble |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Have you had the front brakes checked for a sticking calliper, or even if they’re full of crud they could be causing it to stick slightly and give a wobble. I had this on one of my l322’s and it turned out to be a sticking brake. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 838 ![]() ![]() |
Dodgy wheel bearings can also make moaning / humming / grinding sounds
Faversham Member Since: 09 Mar 2023 Location: Farkhem Hall Posts: 15 ![]() ![]() ![]() |
Thanks Dave I did ask the Indy to check that recently and they said no issue. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan ************************************************* 2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current 2006 L322 Vogue SE 3.6 Java Black/Sand - Current 2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - Dead & Gone 2018 Discovery 5 - Gone 2017 Discovery 5 - Gone 2016 Discovery 4 Landmark - Gone 1997 P38 Vogue - Gone 1988 LR 110 V8 County - Gone 1981 LR 109 Stage 1 V8 County - Gone |
Unnecessary quote removed
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Did you tighten the control arm bolts with the weight of the car on them? |
If the issue started after the control arms were replaced…that’s where I would be looking first |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
Agree with what Rambles just said ^^^
Agree with suggestion above that it could also be worn / out-of-adjustment rack (pre-load).
No it started at about the same time if I recall, replacing one of the control arms was an attempt to resolve it. One had been replaced at the same time as the brakes and another at a later date. Both made no difference. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan ************************************************* 2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current 2006 L322 Vogue SE 3.6 Java Black/Sand - Current 2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - Dead & Gone 2018 Discovery 5 - Gone 2017 Discovery 5 - Gone 2016 Discovery 4 Landmark - Gone 1997 P38 Vogue - Gone 1988 LR 110 V8 County - Gone 1981 LR 109 Stage 1 V8 County - Gone |
@D3jon
A sticking calliper could have caused your original problem of warped discs, so could be the problem once again.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
I’ve got much the same issues that you have and it’s driving me crazy! I’ve had two trusted garages check it over and they can’t find anything wrong. Hunter alignment done a few times all green yet I have to steer slightly to the right to go straight unless the camber slopes to the right.
I also had my tyres "blocked" on the outer edges which suggests play somewhere. Its going in for some other stuff tomorrow so if they find anything, I'll report back. "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan
KN Member Since: 07 Jan 2025 Location: Chandigarh Posts: 14 ![]() ![]() |
6sz I x 9 Standard 2000 (Rover Sd1) 1989 - 1992
