Home > Maintenance & Mods (L322) > Aggravating Wheel Wobble
KN
India
Phone was unlocked and I was logged in. Apology and request for removal of this post.
Thanks
KN Standard 2000 (Rover Sd1) 1989 - 1992
Tata Sierra 1994 - 2000
Ford Escort 1.6
Daewoo cielo
Peugeot 309
Nissan X trail t30 2005 still there
Rexton 2.7xdi still there
L322 October 2024
Post #717814 12th May 2025 5:04pm
Faversham
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Galway Green
Well that's frustrating.....
The fatty is back from my indy and I am about a grand lighter, but at least the g/box, t/box and diffs won't need looking at for a while. The rear washer works again too. However, they couldn't find anything obviously wrong to cause this wheel wobble so it looks like I am going to have to do some digging myself.
I have taken D3Jon's advice and have bought a little IR thermometer so first job over the weekend will be to check the disc temps. I've a sneaky feeling it might be a sticky caliper/warped discs but if not then I'll be stumped. It may mean a trip down to Dursley to see if Craig can track the issue down.... "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan
2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current
2006 L322 Vogue SE 3.6 Java Black/Sand - Current
2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - Dead & Gone
2018 Discovery 5 - Gone
2017 Discovery 5 - Gone
2016 Discovery 4 Landmark - Gone
1997 P38 Vogue - Gone
1988 LR 110 V8 County - Gone
1981 LR 109 Stage 1 V8 County - Gone
Post #718038 16th May 2025 11:38am
Gremlin500
I’d get a dial gauge and check the run out of the discs, (there’s a procedure in the WM above) have you removed and checked that all four front brake pads are the same thickness N/S/E/W? Uneven lining wear means a misaligned or sticking caliper. V6 Vogue - “Less is More” - less to go wrong!
Post #718044 16th May 2025 12:21pm
Faversham
Hi Gremlin
I'd hoped my indy would put a dial guage across the discs but I don't think they went that far. As far as the pads go they have said previously when I asked them about this issue that the pads were wearing evenly but I'm going to have the rims off and have a look for myself and also try D3Jon's suggestion of checking disc temps in case the caliper is binding just slightly.
Failing that, if I can't find anything conclusive, then it'll be a trip to Dursley... "Patience" - a word invented by dull b*ggers who can't think fast enough" - Spike Milligan
Post #718064 16th May 2025 4:06pm
D3Jon
Glad you're getting a non-contact thermometer! It's a great piece of diagnostic kit for brakes, wheel bearings, tyre temperatures, cooling issues (cold spots in rads, etc). I've also used mine to balance my central heating system!
Let us all know how you get on. Thumbs Up
Warped discs would generally only show themselves when you actually brake, once the pads have been 'knocked back' by the disc run-out, there will be no vibration whilst driving along.
However, a sticking calliper would cause the pad to be in contact with the disc the whole time and cause both heat build up and vibration, which would get worse with the heat build up.
As I mentioned before, a mis-adjusted or sticking handbrake can do the same, so don't forget to check the rear handbrake drums as well!
Finally, if you still have issues, dynamic balancing might be of benefit to you. Find a specialist who can do this, it involves balancing the wheels whilst still fitted to the vehicle.
Finally, finally, it could be play in the steering rack (can't remember if I, or someone else, has already mentioned this earlier in the thread). It's not uncommon for the pre-load to require a tweak to eliminate lash in the steering rack.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #718128 17th May 2025 10:28pm
