![]() | Home > Maintenance & Mods (L322) > Rear arch / sill rust |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 170 ![]() ![]() ![]() |
I would remove tge arch liner and repeat your cleaning process. I would use a quality rust converter next followedby spraying a rust proofer like waxoyle into the inside of the cill.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 767 ![]() ![]() |
I'm pretty sure that it is fixable - anything is with enough time/effort/money. Personally I'd be looking at the rest of the car before commiting, sadly a lot of L322s (along with most other older high end cars) are just 1 big problem away from becoming either a "project" on Ebay or being reincarnated as a coke can. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3240 ![]() ![]() ![]() |
I've just done mine:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
You don't appear to have done enough rust removal, as David says you need a wire brush in a drill and you need to get off not just the surface rust but the scale as well, I have marked on the photo a line you can see is the edge of the scale, go over the whole area with a small toffee hammer and get all the scale off, if you treat it as is it will rust between the layers...
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 92 ![]() ![]() ![]() |
Thanks all for the input, it is much appreciated. It does appear things are much worse than first meets the eye!
There should be an independent closeish to you, ask them who does their welding, a lot of garages out source welding now...
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 388 ![]() ![]() ![]() |
Looks to me like it might be time to do it properly. I sell both those sill repair panels and the jacking points. You just need to locate a good local welder. 2017 4.4 SDV8 Autobiography in black
Thanks Stuart - definitely time. I was looking at your site to gauge pricing, I noticed one seller on eBay lists the lower tub panels as an additional piece but only as part of a 'pack'. Are these bits really necessary? Also, how long are the sill sections you supply?
Nobody has ever asked for the additional piece. And I have seen no mention of it here in posts passim. The other seller you speak of makes them individually to order - with a few weeks lead time - so it costs him little to offer an extra part.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 212 ![]() ![]() ![]() |
£1,500 per side is a rip off. My local painter/welder does around 8-9 of these a year and charges around £350 per side. |
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 53 ![]() ![]() ![]() |
2x arches, 2x jack points plus sills and paint on 5 panels cost me around 2k. £1500 a side is definitely on the expensive side of these jobs. Make sure inner sills are checked too😏 2010 Supercharged |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 607 ![]() ![]() ![]() |
cost me £1300 welding and painting i think. i got the parts |
Thanks all for the comments, looks like I need to do some more phoning around!
Order placed for both sides! Got a quote of £600-800 for each side depending on how bad it is - so mind made up and just going to get it done. Cheers |
