|  | Home > Maintenance & Mods (L322) > Rear arch / sill rust |
| Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 215      | I would remove tge arch liner and repeat your cleaning process. I would use a quality rust converter next followedby spraying a rust proofer like waxoyle into the inside of the cill.
|  17th May 2025 3:48pm |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797    | I'm pretty sure that it is fixable - anything is with enough time/effort/money. Personally I'd be looking at the rest of the car before commiting, sadly a lot of L322s (along with most other older high end cars) are just 1 big problem away from becoming either a "project" on Ebay or being reincarnated as a coke can. | ||
|  17th May 2025 4:58pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I've just done mine:
|  17th May 2025 9:13pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | You don't appear to have done enough rust removal, as David says you need a wire brush in a drill and you need to get off not just the surface rust but the scale as well, I have marked on the photo a line you can see is the edge of the scale, go over the whole area with a small toffee hammer and get all the scale off, if you treat it as is it will rust between the layers...
|  18th May 2025 11:14am |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Thanks all for the input, it is much appreciated. It does appear things are much worse than first meets the eye!
|  18th May 2025 1:05pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | There should be an independent closeish to you, ask them who does their welding, a lot of garages out source welding now...
|  18th May 2025 6:44pm |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    | Looks to me like it might be time to do it properly. I sell both those sill repair panels and the jacking points. You just need to locate a good local welder. 2017 4.4 SDV8 Autobiography in black
|  20th May 2025 2:09pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Thanks Stuart - definitely time. I was looking at your site to gauge pricing, I noticed one seller on eBay lists the lower tub panels as an additional piece but only as part of a 'pack'. Are these bits really necessary? Also, how long are the sill sections you supply?
|  20th May 2025 4:35pm |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    | Nobody has ever asked for the additional piece. And I have seen no mention of it here in posts passim. The other seller you speak of makes them individually to order - with a few weeks lead time - so it costs him little to offer an extra part.
|  20th May 2025 6:36pm |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | £1,500 per side is a rip off. My local painter/welder does around 8-9 of these a year and charges around £350 per side. | ||
|  20th May 2025 6:42pm |
| AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 72      | 2x arches, 2x jack points plus sills and paint on 5 panels cost me around 2k. £1500 a side is definitely on the expensive side of these jobs. Make sure inner sills are checked too😏 2010 Supercharged | ||
|  20th May 2025 7:26pm |
| MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 621      | cost me £1300 welding and painting i think. i got the parts | ||
|  20th May 2025 7:46pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Thanks all for the comments, looks like I need to do some more phoning around!
|  20th May 2025 8:16pm |
 Order placed for both sides! Got a quote of £600-800 for each side depending on how bad it is - so mind made up and just going to get it done. Cheers | ||
|  23rd May 2025 12:51pm |
| Posting Rules
