![]() | Home > Maintenance & Mods (L405) > Replacing batteries - supplier and type |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
It's all here - https://www.fullfatrr.com/forum/topic65160.html |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Brilliant….thought someone would be able to help me. Many thanks👍 L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
All sorted Alistair….ordered both batteries from Tayna so should have them delivered next Tuesday/Wednesday 🤞 One final question, do both batteries need to be registered or just the main one? Best regards Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
You should register both batteries. _______________________________________________
Ok. Thanks. I have an icarsoft obd reader and it can register batteries apparently L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
A few final points....maybe....but wondered if someone can help me.
Depends on the reset tool that you use. I have a couple but using the iCarSoft LR v3 it knows there are 2 batteries and so you are able to reset each one individually. _______________________________________________
Thanks. I have the LRV2.0 but checking with icarsoft as to what my version will do. It’s supposed to cover my year so once I find out I’ll let you know. L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Can you explain the process you went through please as icarsoft have told me the V3.0 doesn’t support the 2 battery setup/registration? I was hoping the V3.0 would be able to do it but I must be missing something somewhere…..any help would be greatly appreciated as I need to get my batteries swapped out soon. Best regards Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
This should help you
Hi
I actually have the choice of battery on my screen. I would take a picture but I am at work so cant do that at this time. To be honest there is always an argument as to whether you really need to register a new battery at all because the car will, overtime, work it out itself. I believe the whole reset system is to really prevent the car from overcharging until it works out a new battery has been added.
Thanks for the explanation. I’ll give it a whizz…..if you do get a chance to do a screenshot I’d be very grateful 🙏
Unnecessary quote removed
