![]() | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 95 ![]() ![]() ![]() |
Hi David, how did you drive out the bush with one side having a flange on it and getting in the way. I'm thinking of doing mine soon. Do you also think a 10 Ton press will be up to the job?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3311 ![]() ![]() ![]() |
The lower wishbones don't have the flange on them, that's only on the upper ones.
Cheers for that David. At least I now know that there is no way of pressing them out. I will just go carefully when driving them out by hand. 2010 RR Autobiography 5.0 SC
Have a look at my post here from 26th March 2022.
Great reading. many thanks! |
Managed to get the rear wishbones refitted tonight.
Oh yea... I found a pair of genuine Land Rover keyrings that I bought from Duckworths Land Rover years ago so put one of them on the key for this RR tonight.
Finished cleaning up the steel behind where the jacking points are mounted today. Quite pleased with how they've both turned out.
Another job for this afternoon was to change the track rod ends.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8731 ![]() ![]() ![]() |
Top jobs as always David, those wheels were on my S\C when I bought it, mine were diamond cut which always leads to corrosion, looks like yours have been painted or powder coated over the top...!!!
Thanks Pete.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1029 ![]() ![]() |
Outstanding work !! |
Yes David, you need all the help you can get with the winters you get up there... |
Thanks |
