|  | Home > Technical (L322) > 4.4 TDV8 no start no crank |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | looking forwards to following the rebuild. 2012 TDV8 Vogue (L322) | ||
|  19th Jul 2022 1:17pm |
| PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84    |
 Thanks for the tip Johnboyairey! Mine was already partially fixed. I mean, the old one was still in the manifold unplugged and a new one was connected to the harness and just tied to the side of the manifold  So will get it right before putting things back   | ||
|  19th Jul 2022 7:55pm |
| batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 209    | Good luck with this job, and I must say I'm looking forward to seeing any videos that you do   | ||
|  20th Jul 2022 11:28am |
| JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 72      | Hi Peter,
|  29th Nov 2022 8:20pm |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 355      | Cliff hanger!!!
|  25th May 2023 12:41pm |
| PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84    | Hi gentlemen, sorry for a long silence. This engine rebuild has been a real curse on me. The good news is that I after a long struggle I've managed to rebuild the engine and put it back in the car. The bad news is that it still doesn't start. So once again, I need to ask for help from the much wiser community here. The long story short, it seems like I'm not getting the high fuel pressure required in the fuel rail.
|  31st May 2025 10:28am |
|  31st May 2025 10:30am |
| toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 315    | The pressures are fine on the low and high side for starting. I have a similar issue but I am stuck also (not after an engine rebuild though).
|  2nd Jun 2025 8:10am |
| PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84    | deleted comment | ||
|  2nd Jun 2025 8:23am |
| PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84    | I used a £20 diesel fuel pressure gauge tester off Amazon to connect it to the fuel filter | ||
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 462      | Did you set the HPFP to the correct position when assembling?
|  2nd Jun 2025 8:28am |
| PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84    | Yes, I also purchased the genuine fuel pump timing tool to time the pump correctly. One thing I didn't have or use was the LH bank sprocket locking tool (JLR-310-247). I just used the LASER timing (cam locking) kit to do the timing.. My understanding is that the bank sprocket locking tool is meant to simplify the timing process, but not absolutely necessary, am I correct? I did manage to tighten the cam sprockets to spec using the cam locking tools. I wonder now if I've missed something, it was almost a year ago now... | ||
|  2nd Jun 2025 9:17am |
| Posting Rules
