![]() | Home > Technical (L322) > 4.4 TDV8 no start no crank |
looking forwards to following the rebuild. 2012 TDV8 Vogue (L322) |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 84 ![]() ![]() |
Thanks for the tip Johnboyairey! Mine was already partially fixed. I mean, the old one was still in the manifold unplugged and a new one was connected to the harness and just tied to the side of the manifold ![]() ![]() |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
Good luck with this job, and I must say I'm looking forward to seeing any videos that you do |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 71 ![]() ![]() ![]() |
Hi Peter,
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Cliff hanger!!!
Hi gentlemen, sorry for a long silence. This engine rebuild has been a real curse on me. The good news is that I after a long struggle I've managed to rebuild the engine and put it back in the car. The bad news is that it still doesn't start. So once again, I need to ask for help from the much wiser community here. The long story short, it seems like I'm not getting the high fuel pressure required in the fuel rail.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 272 ![]() ![]() |
The pressures are fine on the low and high side for starting. I have a similar issue but I am stuck also (not after an engine rebuild though).
deleted comment |
deleted comment |
deleted comment |
I used a £20 diesel fuel pressure gauge tester off Amazon to connect it to the fuel filter |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 346 ![]() ![]() ![]() |
Did you set the HPFP to the correct position when assembling?
Yes, I also purchased the genuine fuel pump timing tool to time the pump correctly. One thing I didn't have or use was the LH bank sprocket locking tool (JLR-310-247). I just used the LASER timing (cam locking) kit to do the timing.. My understanding is that the bank sprocket locking tool is meant to simplify the timing process, but not absolutely necessary, am I correct? I did manage to tighten the cam sprockets to spec using the cam locking tools. I wonder now if I've missed something, it was almost a year ago now... |
