Home > Maintenance & Mods (L405) > aux belt/pulleys
Gremlin500
@4RRS:
There’s a procedure in the WM for in-situ replacement of the V6 oil pump, without dropping the sump:
This is acedemic however, as it doesn’t help our V8 owner! Embarassed V6 Vogue - “Less is More” - less to go wrong!
Post #719021 2nd Jun 2025 1:08pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
@Gremlin500, That's good to know as I've got a SDV6 L494 and it will be due a pump as it's nearly hit 275K, mabye I'll do it when I do the belts for the third time Laughing L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719026 2nd Jun 2025 2:15pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
which dose makes sense as apart from engine size the pumps look very similar and the procedure is much the same ........there has to be someone who has had the oil pump replaced or is it that the sdv8 oil pump is the most reliable part on the engine ..hmmm .i dont know just going to go on collecting the other parts for now and see what happens on here
Post #719027 2nd Jun 2025 2:17pm
Gremlin500
I’d be careful Will, I’m not saying the same procedure is OK for the V8 at all Shocked
@4RRS, important to be super-clean/careful when doing the little sealant beads in the 2 bottom corners, it’s in the WM. V6 Vogue - “Less is More” - less to go wrong!
Post #719034 2nd Jun 2025 3:38pm
will308f
no im not going to replace the oil pump Thumbs Up
Post #719035 2nd Jun 2025 3:53pm
will308f
dose anybody know if this part (LR025988) which is from the alternator idler pully on the l322 fit the alternator pully on the l405 or do you have to replace the bracket ?
Post #719228 5th Jun 2025 8:05pm
4RRS
I came across this when rebuilding mine and was a little annoyed to find it was the only idler you couldn't buy separately and had to buy the idler and bracket for £200+ L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719230 5th Jun 2025 8:13pm
will308f
yea that's it, at the end of the day you just need the pully the bracket is never going to break such a rip off.......thinking about just getting it and take off the original pully and see if they are the same can always return it
Post #719234 5th Jun 2025 8:27pm
4RRS
It's a different diameter to all the other pulleys on the 405, maybe worth a shot using a 322 version, I just didn't have the will to mess about so swallowed the cost with a bad taste. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719237 5th Jun 2025 8:36pm
will308f
yea decided to get both parts and see if it fit and just return what i don't use .at least it will be some use to other ppl Thumbs Up
Post #719238 5th Jun 2025 8:47pm
will308f
this is a part number for a pully that fits on the alternated bracket (febest 1287-ix55 ) ...a l405 user fitted this last year straight swap and has had no issues got one on order Thumbs Up
Post #719555 10th Jun 2025 7:17pm
4RRS
Good to know, I'll keep a note of that for the future Thumbs Up L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719557 10th Jun 2025 7:45pm
will308f
hopefully this will help others too Thumbs Up
Post #719559 10th Jun 2025 7:47pm
will308f
Just received this ,the pulley for the alternator bracket and the quality seems just as good as the genuine idler pulleys I have got
The cost of this was £45 as opposed to £250-260 for the bracket/pulley and even if it last for 2-3 years maybe more it’s still a better buy I think Thumbs Up
Post #719916 17th Jun 2025 11:50am
